Casablanca W-11 Wall Control Switch Replacement
  1. Casablanca W-11 Wall Control Switch  Replacement, Replace Burned Out Main Power Switch: step 1, image 1 of 3 Casablanca W-11 Wall Control Switch  Replacement, Replace Burned Out Main Power Switch: step 1, image 2 of 3 Casablanca W-11 Wall Control Switch  Replacement, Replace Burned Out Main Power Switch: step 1, image 3 of 3
    • Apparently W-11 is obsolete and replaced by W-32 which is also obsolete.
    • Main power switch was burned out. You can see lots of black around contacts of switch I took apart.
    • I replaced it with a rocker switch (Digikey EG1510-ND, $1 switch + $5 shipping). It's the wrong color but brown switches are hard to find.
    • New switch has on/off marking. Original switch always annoyed me because I could not tell if it was on or off.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Important: Buy SPST or SPDT switch or connectors won’t fit.
2 other people completed this guide.
Alan Nishioka
3,655 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 55
Past 30 Days: 151
All Time: 6,211
