Casablanca Intelli-Touch W-11 control testing
    1. Casablanca Intelli-Touch W-11 control testing, Test wiring: step 1, image 1 of 1
      • Connect the hot side of an AC power cord to the Line In to the W-11
      • Connect the neutral side to a light bulb, lamp, etc.
      • Connect the Line Out of the WC-11 to the other side of the light bulb. Use a jumper wire.
      • Connect the oscilloscope leads to the hot and neutral sides of the light bulb.
      • Be sure that all the wiring is secure so that nothing shorts out during the testing.
      • Plug in the AC plug to a 110 volt outlet
      Ask FixBot
    2. Casablanca Intelli-Touch W-11 control testing, Power test: step 2, image 1 of 1
      • Turn on the W-11 power switch.
      • Does the light turn on? If not, check your wiring.
      • Turn off the power, take apart the W-11 and test the power switch with a continuity tester/multimeter.
      • Set up the oscilloscope to observe the AC sine wave.
      Ask FixBot
    3. Casablanca Intelli-Touch W-11 control testing, Test the light button: step 3, image 1 of 1
      • Press the Light button
      • Check the ossilloscope.
      • Do you see the small signal that appears on the rising side of the AC sine wave?
      Ask FixBot
    4. Casablanca Intelli-Touch W-11 control testing, Test the fan button: step 4, image 1 of 1
      • Press the fan button
      • Do you see the signal on the falling side of the AC sine wave?
      Ask FixBot
    5. Casablanca Intelli-Touch W-11 control testing, Test both switches: step 5, image 1 of 1
      • Press the fan and light switches simultaneously.
      • Do you see the signals on both the rising and falling sides of the AC sine wave?
      Ask FixBot
Finish Line
Wayne Seltzer
1,860 Reputation
10 Guides authored
Global Fixers Member of Global Fixers
Community
68 Members
2,266 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 80
All Time: 1,907
