Carrier 58MSA060-08 Furnace Filter Replacement
  1. Carrier 58MSA060-08 Furnace Filter Replacement, Furnace Filter: step 1, image 1 of 2 Carrier 58MSA060-08 Furnace Filter Replacement, Furnace Filter: step 1, image 2 of 2
    • Locate the furnace disconnect switch.
    • Flip the switch from the "ON" position to the "OFF" position.
    Ask FixBot
  2. Carrier 58MSA060-08 Furnace Filter Replacement: step 2, image 1 of 1
    • The filter is located in between the return duct and the main furnace unit.
    Ask FixBot
  3. Carrier 58MSA060-08 Furnace Filter Replacement: step 3, image 1 of 3 Carrier 58MSA060-08 Furnace Filter Replacement: step 3, image 2 of 3 Carrier 58MSA060-08 Furnace Filter Replacement: step 3, image 3 of 3
    • Pull the filter cover off of the duct to remove it and expose the filter.
    Ask FixBot
  4. Carrier 58MSA060-08 Furnace Filter Replacement: step 4, image 1 of 2 Carrier 58MSA060-08 Furnace Filter Replacement: step 4, image 2 of 2
    • Examine your furnace to determine the air flow direction.
    • The Return Duct
    • The Furnace Unit
    • The air will always flow from the return duct towards the furnace unit.
    • Your old filter may also have an arrow indicator on the side.
    • The arrow's direction will indicate the air flow direction.
    Ask FixBot
  5. Carrier 58MSA060-08 Furnace Filter Replacement: step 5, image 1 of 3 Carrier 58MSA060-08 Furnace Filter Replacement: step 5, image 2 of 3 Carrier 58MSA060-08 Furnace Filter Replacement: step 5, image 3 of 3
    • Remove the old filter by pulling it out of the duct.
    Ask FixBot
  6. Carrier 58MSA060-08 Furnace Filter Replacement: step 6, image 1 of 3 Carrier 58MSA060-08 Furnace Filter Replacement: step 6, image 2 of 3 Carrier 58MSA060-08 Furnace Filter Replacement: step 6, image 3 of 3
    • Insert the new filter.
    • Pay attention to which direction the new filter should face before inserting it; make it is correct.
    Ask FixBot
  7. Carrier 58MSA060-08 Furnace Filter Replacement: step 7, image 1 of 2 Carrier 58MSA060-08 Furnace Filter Replacement: step 7, image 2 of 2
    • Reattach the filter cover.
    • Ensure that the filter cover is securely in place.
    Ask FixBot
  8. Carrier 58MSA060-08 Furnace Filter Replacement: step 8, image 1 of 2 Carrier 58MSA060-08 Furnace Filter Replacement: step 8, image 2 of 2
    • Turn on the furnace.
    • Flip the switch from the "OFF" position to the "ON" position.
    Ask FixBot
Once you have completed these steps, your furnace filter replacement will be complete.
2 other people completed this guide.
Alexander Ye
184 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 50
Past 30 Days: 184
All Time: 9,673
