Carrera Mario Copter Controller Circuit Board Replacement
  1. Carrera Mario Copter Controller Circuit Board Replacement, Controller Circuit Board: step 1, image 1 of 1
    • Flip the controller over so the underside would face up
    • Remove four of 7.1mm screws with a JIS #1 screwdriver
    • Remove two 4.0mm screws located on the handle with the JIS #1screwdriver.
    • Remove two 7.1 mm screws on the small area that stick out from the surface with the JIS #1 screwdriver
    • Use an extension with the JIS #1 screwdriver in order to get to the screws with yellow marks because they locate deep inside the holes.
  2. Carrera Mario Copter Controller Circuit Board Replacement: step 2, image 1 of 1
    • Remove the black case to access the circuit board.
    • Remove two 4.8mm screws on the circuit board with the JIS #1 screwdriver.
  3. Carrera Mario Copter Controller Circuit Board Replacement: step 3, image 1 of 1
    • Gently lift up the circuit board from the black case.
    • Use a soldering iron to melt the red wire while at the same time pulling it from the motherboard.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Repeat the previous procedure with the black wire.
    • Gently remove the circuit board away from the case.
Edgar Lopez-Allende
207 Reputation
2 Guides authored
UW Tacoma, Team S1-G6, Rose Fall 2017 Member of UW Tacoma, Team S1-G6, Rose Fall 2017
UWT-ROSE-F17S1G6
4 Members
11 Guides authored
1 Guide Comment
i don't have the receiver. what can i pair with?
Ali Ali - Reply Share
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 41
All Time: 585
