Cardinal Health Vela Ventilator Left Panel Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Cardinal Health Vela Ventilator Left Panel Replacement, Power Cable: step 1, image 1 of 1
    • Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
    Ask FixBot
    • Remove the plug guard and unplug the ventilator.
    Ask FixBot
  2. Cardinal Health Vela Ventilator Left Panel Replacement, Cardinal Health Vela Ventilator Top Cover Disassembly: step 3, image 1 of 1
    • Remove the four Phillips #0 screws on the back side of the ventilator.
    Ask FixBot
  3. Cardinal Health Vela Ventilator Left Panel Replacement: step 4, image 1 of 1
    • Remove all six small side panel screws along the bottom of each side of the top cover with the same screwdriver.
    Ask FixBot
    • Slide the top cover towards the back side of the ventilator to remove it.
    Ask FixBot
  4. Cardinal Health Vela Ventilator Left Panel Replacement, Battery Tray: step 6, image 1 of 1
    • Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
    Ask FixBot
    • Lift the battery tray out of the ventilator.
    • Caution: The wires connecting the batteries to the ventilator will still be connected so lift the battery tray carefully.
    Ask FixBot
  5. Cardinal Health Vela Ventilator Left Panel Replacement: step 8, image 1 of 1
    • Disconnect the batteries from the ventilator by pulling apart the Battery Connector.
    Ask FixBot
    • Remove the two Phillips countersink at the rear of the panel.
    Ask FixBot
    • Remove the Phillips countersink in the upper front of the panel.
    Ask FixBot
    • The panel is now free and can be lifted from the device.
    Ask FixBot
    • To install the left panel follow these steps in reverse order.
    Ask FixBot
Tanner Hillman
370 Reputation
3 Guides authored
Cal Poly, Team S7-G22, Paton Spring 2020 Member of Cal Poly, Team S7-G22, Paton Spring 2020
CPSU-PATON-S20S7G22
1 Member
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 15
All Time: 272
