Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Featured Document
  1. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement, Flow Sensor Receptacle: step 1, image 1 of 1
    • Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
    Ask FixBot
    • Remove the plug guard and unplug the ventilator.
    Ask FixBot
  2. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: step 3, image 1 of 1
    • Remove the 4 Phillips pan-head screws on the back side of the ventilator.
    Ask FixBot
  3. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: step 4, image 1 of 1
    • Remove all six small side panel screws along the bottom of each side of the top cover.
    Ask FixBot
    • Slide the top cover towards the back side of the ventilator to remove it.
    Ask FixBot
  4. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: step 6, image 1 of 1
    • Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
    Ask FixBot
    • Lift the battery tray out of the ventilator.
    • Caution: The wires connecting the batteries to the ventilator will still be connected so lift the battery tray carefully.
    Ask FixBot
  5. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: step 8, image 1 of 1
    • Disconnect the batteries from the ventilator by pulling apart the Battery Connector.
    Ask FixBot
  6. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: step 9, image 1 of 1
    • Remove the 2 Phillips countersink screws from the right side of the rear panel.
    Ask FixBot
  7. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: step 10, image 1 of 1
    • Remove the 1 Phillips countersink screw in the upper front of the right panel.
    Ask FixBot
  8. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: step 11, image 1 of 1
    • Remove the 1 Phillips pan-head screw in the lower center of the right panel.
    Ask FixBot
  9. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: step 12, image 1 of 1
    • Gently lift out the panel and the power PCB. Lay the panel flat and make the following disconnections:
    Ask FixBot
    • Remove the 2 Phillips countersink screws at the rear of the left panel.
    • Remove the 1 Phillips countersink screw in the upper front of the left panel.
    • Lift out the left panel.
    Ask FixBot
    • Disconnect the following from the main PCB:
    • JP2 40-pin ribbon cable to JP1 on the SVGA out PCB
    • J301 12-pin to J301 on the blender PCB
    Ask FixBot
  10. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: step 15, image 1 of 1
    • Disconnect the green oxygen nebulizer tube
    • Remove the 2 Phillips pan-head screws behind the front panel at the lower left and right.
    • Disconnect the 1/8” silicone tube #4 from P2 on the exhalation differential transducer
    • Disconnect the 1/8” silicone tube #5 from P1 on the exhalation differential transducer
    • Disconnect the 1/8” silicone tube #1 from the turbine
    Ask FixBot
    • Disconnect the 1/16” silicone tube from the front ports of the turbine outlet auto-zero solenoid that goes to the main tubing harness.
    • Disconnect the 1/16” silicone tube from the turbine inlet auto-zero solenoid that goes to the turbine.
    • Disconnect the 1/16” silicone tube from the airway pressure auto-zero solenoid that goes to the exhalation valve receptacle.
    Ask FixBot
  11. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: step 17, image 1 of 1
    Ask FixBot
  12. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: step 18, image 1 of 1
    Ask FixBot
  13. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: step 19, image 1 of 1
    • Loosen 7 Phillips pan-head screws on the main PCB.
    Ask FixBot
    • Lift the main PCB out of the front panel.
    Ask FixBot
  14. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: step 21, image 1 of 1
    • Disconnect the 2 1/16” ID tubes to the main tubing harness
    Ask FixBot
  15. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: step 22, image 1 of 1
    • Disconnect the grey 6-pin connector.
    Ask FixBot
  16. Cardinal Health Vela Ventilator Flow Sensor Receptacle Replacement: step 23, image 1 of 1
    • Remove the 2 1/4” nuts on the flow sensor PCB.
    Ask FixBot
    • Lift off the flow sensor PCB
    Ask FixBot
Attached Documents
Ethan Nikcevich
649 Reputation
2 Guides authored
Cal Poly, Team S11-G22, Paton Spring 2020 Member of Cal Poly, Team S11-G22, Paton Spring 2020
CPSU-PATON-S20S11G22
2 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 29
All Time: 436
