Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓In this guide, you will be instructed on how to adjust and synchronize the output of the two carburetors.
Parts
Tools
Use a 3/8 socket wrench to loosen the retaining bolts on the air cleaner.
Rotate the air cleaner so that the throats of both carburetors are clear. Now you will be able to adjust them.
Start the engine
Congratulations, your Corvair should now idle properly. If the Carburetors are still not operating properly, then the linkage is not synchronized, or they are in need of repair or rebuild. (A linkage adjustment and rebuild guide will be made soon!)
26 other people completed this guide.
1 Guide Comment
Bonjour,
Ma corvair a 4 carburateurs.
Est-ce que le ralenti se règle individuellement sur chaque ?
Merci
