Up to 20% off select tools
Capresso Infinity Timer/On Switch Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
117
All Time:
4,106
Comments: 16
9 comments on steps, 7 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you need to replace the timer/on switch, follow this guide. The timer/on switch is essential to how long the coffee beans take to turn into coffee grounds. For this guide, you will need the Torx Security T10 Bit Screwdriver, the extension bit, and a soldering iron.
    1. Capresso Infinity Timer/On Switch Replacement, Metal Outside Casing: step 1, image 1 of 2 Capresso Infinity Timer/On Switch Replacement, Metal Outside Casing: step 1, image 2 of 2
      • Twist the top plastic container to the left counterclockwise.
      • Pull upwards to remove.
      Ask FixBot
    2. Capresso Infinity Timer/On Switch Replacement: step 2, image 1 of 3 Capresso Infinity Timer/On Switch Replacement: step 2, image 2 of 3 Capresso Infinity Timer/On Switch Replacement: step 2, image 3 of 3
      • Twist the top burr to the left counter clockwise.
      Ask FixBot
    3. Capresso Infinity Timer/On Switch Replacement: step 3, image 1 of 2 Capresso Infinity Timer/On Switch Replacement: step 3, image 2 of 2
      • Flip entire device upside down.
      • Remove two rubber coverings on the back of the device.
      Ask FixBot
    4. Capresso Infinity Timer/On Switch Replacement: step 4, image 1 of 2 Capresso Infinity Timer/On Switch Replacement: step 4, image 2 of 2
      • Remove four 11.59mm T10 screws.
      • The screws will have small circular washers under them. Put them aside for reassembly.
      Ask FixBot
    5. Capresso Infinity Timer/On Switch Replacement: step 5, image 1 of 3 Capresso Infinity Timer/On Switch Replacement: step 5, image 2 of 3 Capresso Infinity Timer/On Switch Replacement: step 5, image 3 of 3
      • Lift the metal outside casing off the black base.
      • Flip the outside casing forward so you have access to the inside of it.
      Ask FixBot
    6. Capresso Infinity Timer/On Switch Replacement: step 6, image 1 of 3 Capresso Infinity Timer/On Switch Replacement: step 6, image 2 of 3 Capresso Infinity Timer/On Switch Replacement: step 6, image 3 of 3
      • Remove one 11.59mm T10 screw.
      • Let the green wire fall, or place somewhere so it doesn't get in the way.
      • There will be a small metal retainer and washer, put them aside for reassembly.
      Ask FixBot
    7. Capresso Infinity Timer/On Switch Replacement: step 7, image 1 of 3 Capresso Infinity Timer/On Switch Replacement: step 7, image 2 of 3 Capresso Infinity Timer/On Switch Replacement: step 7, image 3 of 3
      • Remove two 11.59mm T10 screws.
      Ask FixBot
    8. Capresso Infinity Timer/On Switch Replacement: step 8, image 1 of 2 Capresso Infinity Timer/On Switch Replacement: step 8, image 2 of 2
      • Remove the time/on switch by pulling upwards.
      Ask FixBot
    1. Capresso Infinity Timer/On Switch Replacement, Timer/On Switch: step 9, image 1 of 1
      • Strip the two wires of their black covering connecting them to the black box.
      Ask FixBot
    2. Capresso Infinity Timer/On Switch Replacement: step 10, image 1 of 3 Capresso Infinity Timer/On Switch Replacement: step 10, image 2 of 3 Capresso Infinity Timer/On Switch Replacement: step 10, image 3 of 3
      • Solder the two cords holding in the blue and white wire in the black timer box.
      Ask FixBot
3 other people completed this guide.
Author
with
Melayne Spataro
272 Reputation
1 Guide authored
USF Tampa, Team S1-G1, Leahy Fall 2018 Member of USF Tampa, Team S1-G1, Leahy Fall 2018
USFT-LEAHY-F18S1G1
4 Members
60 Guides authored
7 Guide Comments
do you know where I can get a new black timer box?
geclay@hotmail.com - Reply Share
Where can I purchase a timer/on switch?
Rob Gordon - Reply Share
Same question here, where can I buy this part?
Dominic Daigle - Reply Share
Just piling on,has anyone found where to buy the Timer switch?
Chris DiNicolas - Reply Share
Same, looking for part number and/or where to buy the timer dial.
Hans Sorensen - Reply Share
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 117
All Time: 4,106
