Up to 20% off select tools
Capresso Infinity Power Cord Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
80
All Time:
1,214
Comments: 9
9 comments on steps.
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Does your Capresso Infinity Coffee Grinder not turn on? Has the power cord started to fray? If so, there might be an issue with your power cord. Here is a guide to replace your Capresso Infinity power cord. All you need is a Torx Security T10 Bit Screwdriver and a 2.0 Flathead Screwdriver in order to remove the screws to replace the power cord.
    1. Capresso Infinity Power Cord Replacement, Metal Outside Casing: step 1, image 1 of 2 Capresso Infinity Power Cord Replacement, Metal Outside Casing: step 1, image 2 of 2
      • Twist the top plastic container to the left counterclockwise.
      • Pull upwards to remove.
      Ask FixBot
    2. Capresso Infinity Power Cord Replacement: step 2, image 1 of 3 Capresso Infinity Power Cord Replacement: step 2, image 2 of 3 Capresso Infinity Power Cord Replacement: step 2, image 3 of 3
      • Twist the top burr to the left counter clockwise.
      Ask FixBot
    3. Capresso Infinity Power Cord Replacement: step 3, image 1 of 2 Capresso Infinity Power Cord Replacement: step 3, image 2 of 2
      • Flip entire device upside down.
      • Remove two rubber coverings on the back of the device.
      Ask FixBot
    4. Capresso Infinity Power Cord Replacement: step 4, image 1 of 2 Capresso Infinity Power Cord Replacement: step 4, image 2 of 2
      • Remove four 11.59mm T10 screws.
      • The screws will have small circular washers under them. Put them aside for reassembly.
      Ask FixBot
    5. Capresso Infinity Power Cord Replacement: step 5, image 1 of 3 Capresso Infinity Power Cord Replacement: step 5, image 2 of 3 Capresso Infinity Power Cord Replacement: step 5, image 3 of 3
      • Lift the metal outside casing off the black base.
      • Flip the outside casing forward so you have access to the inside of it.
      Ask FixBot
    6. Capresso Infinity Power Cord Replacement: step 6, image 1 of 3 Capresso Infinity Power Cord Replacement: step 6, image 2 of 3 Capresso Infinity Power Cord Replacement: step 6, image 3 of 3
      • Remove one 11.59mm T10 screw.
      • Let the green wire fall, or place somewhere so it doesn't get in the way.
      • There will be a small metal retainer and washer, put them aside for reassembly.
      Ask FixBot
    7. Capresso Infinity Power Cord Replacement: step 7, image 1 of 3 Capresso Infinity Power Cord Replacement: step 7, image 2 of 3 Capresso Infinity Power Cord Replacement: step 7, image 3 of 3
      • Remove two 11.59mm T10 screws.
      Ask FixBot
    8. Capresso Infinity Power Cord Replacement: step 8, image 1 of 2 Capresso Infinity Power Cord Replacement: step 8, image 2 of 2
      • Remove the time/on switch by pulling upwards.
      Ask FixBot
    1. Capresso Infinity Power Cord Replacement, Power Cord: step 9, image 1 of 3 Capresso Infinity Power Cord Replacement, Power Cord: step 9, image 2 of 3 Capresso Infinity Power Cord Replacement, Power Cord: step 9, image 3 of 3
      • Remove two 13.60mm T10 screws.
      • A white, flat plastic piece will have come loose. Place this to the side for reassembly.
      Ask FixBot
    2. Capresso Infinity Power Cord Replacement: step 10, image 1 of 3 Capresso Infinity Power Cord Replacement: step 10, image 2 of 3 Capresso Infinity Power Cord Replacement: step 10, image 3 of 3
      • Using a Flathead screwdriver loosen the two screws connecting the white and black wire to the plastic box.
      • Do not remove the screws from the box, but loosen them enough to disconnect the black and white wire.
      Ask FixBot
    3. Capresso Infinity Power Cord Replacement: step 11, image 1 of 3 Capresso Infinity Power Cord Replacement: step 11, image 2 of 3 Capresso Infinity Power Cord Replacement: step 11, image 3 of 3
      • Originally attached to the inside of the outer casing, the green wire needs to be fed through the zip tie which keeps it in place.
      • Lift up on the zip tie far enough to create a space to feed the green wire through.
      • Place the zip tie back around the column that you lifted it from.
      • All three wires that comprise the power cord should be detached from the coffee grinder.
      Ask FixBot
    4. Capresso Infinity Power Cord Replacement: step 12, image 1 of 3 Capresso Infinity Power Cord Replacement: step 12, image 2 of 3 Capresso Infinity Power Cord Replacement: step 12, image 3 of 3
      • Feed the wires through the small hole at the bottom of the coffee grinder where the external power cord is located.
      • Once the power cord is free of the coffee grinder, you are able to put in the new cord.
      Ask FixBot
Author
with
Elizabeth Roach
233 Reputation
1 Guide authored
USF Tampa, Team S1-G1, Leahy Fall 2018 Member of USF Tampa, Team S1-G1, Leahy Fall 2018
USFT-LEAHY-F18S1G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 80
All Time: 1,214
