Up to 20% off select tools
Capresso Infinity Outside Casing Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
81
All Time:
2,236
Comments: 9
9 comments on steps.
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If you need to replace the outside casing, follow this guide. The outside casing is essential to keeping everything inside in place, and protecting the internal structures of the device. If there is cosmetic damage or significant disfigurement, replacement of the metal outside casing is suggested. For this guide, you will need the Torx Security T10 Bit Screwdriver as well as the extension bit.
    1. Capresso Infinity Outside Casing Replacement, Metal Outside Casing: step 1, image 1 of 2 Capresso Infinity Outside Casing Replacement, Metal Outside Casing: step 1, image 2 of 2
      • Twist the top plastic container to the left counterclockwise.
      • Pull upwards to remove.
      Ask FixBot
    2. Capresso Infinity Outside Casing Replacement: step 2, image 1 of 3 Capresso Infinity Outside Casing Replacement: step 2, image 2 of 3 Capresso Infinity Outside Casing Replacement: step 2, image 3 of 3
      • Twist the top burr to the left counter clockwise.
      Ask FixBot
    3. Capresso Infinity Outside Casing Replacement: step 3, image 1 of 2 Capresso Infinity Outside Casing Replacement: step 3, image 2 of 2
      • Flip entire device upside down.
      • Remove two rubber coverings on the back of the device.
      Ask FixBot
    4. Capresso Infinity Outside Casing Replacement: step 4, image 1 of 2 Capresso Infinity Outside Casing Replacement: step 4, image 2 of 2
      • Remove four 11.59mm T10 screws.
      • The screws will have small circular washers under them. Put them aside for reassembly.
      Ask FixBot
    5. Capresso Infinity Outside Casing Replacement: step 5, image 1 of 3 Capresso Infinity Outside Casing Replacement: step 5, image 2 of 3 Capresso Infinity Outside Casing Replacement: step 5, image 3 of 3
      • Lift the metal outside casing off the black base.
      • Flip the outside casing forward so you have access to the inside of it.
      Ask FixBot
    6. Capresso Infinity Outside Casing Replacement: step 6, image 1 of 3 Capresso Infinity Outside Casing Replacement: step 6, image 2 of 3 Capresso Infinity Outside Casing Replacement: step 6, image 3 of 3
      • Remove one 11.59mm T10 screw.
      • Let the green wire fall, or place somewhere so it doesn't get in the way.
      • There will be a small metal retainer and washer, put them aside for reassembly.
      Ask FixBot
    7. Capresso Infinity Outside Casing Replacement: step 7, image 1 of 3 Capresso Infinity Outside Casing Replacement: step 7, image 2 of 3 Capresso Infinity Outside Casing Replacement: step 7, image 3 of 3
      • Remove two 11.59mm T10 screws.
      Ask FixBot
    8. Capresso Infinity Outside Casing Replacement: step 8, image 1 of 2 Capresso Infinity Outside Casing Replacement: step 8, image 2 of 2
      • Remove the time/on switch by pulling upwards.
      Ask FixBot
Author
with
Nina Mackin
609 Reputation
2 Guides authored
USF Tampa, Team S1-G1, Leahy Fall 2018 Member of USF Tampa, Team S1-G1, Leahy Fall 2018
USFT-LEAHY-F18S1G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 81
All Time: 2,236
