Canon ZR70MC LCD Component Replacement
    1. Canon ZR70MC LCD Component Replacement, Front Panel: step 1, image 1 of 2 Canon ZR70MC LCD Component Replacement, Front Panel: step 1, image 2 of 2
      • Unscrew the 3.35mm screw.
      Ask FixBot
    2. Canon ZR70MC LCD Component Replacement: step 2, image 1 of 1
      • Turn the ZR70MC so that you can see the bottom of the camcorder.
      • Unscrew the 3.35 mm located in the top left portion of the camera.
      Ask FixBot
    3. Canon ZR70MC LCD Component Replacement: step 3, image 1 of 3 Canon ZR70MC LCD Component Replacement: step 3, image 2 of 3 Canon ZR70MC LCD Component Replacement: step 3, image 3 of 3
      • Turn the camera on the side and remove the cover for the audio inputs. There is a 2.65 mm screw located behind the cover.
      • Remove the 2.65 mm screw.
      Ask FixBot
    4. Canon ZR70MC LCD Component Replacement: step 4, image 1 of 3 Canon ZR70MC LCD Component Replacement: step 4, image 2 of 3 Canon ZR70MC LCD Component Replacement: step 4, image 3 of 3
      • Remove the cover located on the front of the camcorder and remove the cover by pulling on the bottom groove.
      • Locate and remove the two 3.35 mm screws.
      Ask FixBot
    5. Canon ZR70MC LCD Component Replacement: step 5, image 1 of 2 Canon ZR70MC LCD Component Replacement: step 5, image 2 of 2
      • Turn the camcorder so that the bottom is facing up and open the tape cassette compartment.
      • There is one 3.35 mm screw located under the tape cassette panel on the front left side of the camcorder. Remove the screw.
      Ask FixBot
    6. Canon ZR70MC LCD Component Replacement: step 6, image 1 of 3 Canon ZR70MC LCD Component Replacement: step 6, image 2 of 3 Canon ZR70MC LCD Component Replacement: step 6, image 3 of 3
      • Now that all of the screws are removed, remove the front panel by gently pulling on the front panel.
      • The speaker will be connected to the main body by a wire. Be careful not to damage this wire.
      Ask FixBot
    7. Canon ZR70MC LCD Component Replacement: step 7, image 1 of 3 Canon ZR70MC LCD Component Replacement: step 7, image 2 of 3 Canon ZR70MC LCD Component Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to gently pull the speaker wire from the main body of the camcorder.
      • Pull the front panel completely away from the main body of the camcorder.
      Ask FixBot
    1. Canon ZR70MC LCD Component Replacement, LCD screen: step 8, image 1 of 3 Canon ZR70MC LCD Component Replacement, LCD screen: step 8, image 2 of 3 Canon ZR70MC LCD Component Replacement, LCD screen: step 8, image 3 of 3
      • Open the LCD screen.
      • Locate and remove the 2.7 mm screw on the bottom of the LCD monitor.
      Ask FixBot
    2. Canon ZR70MC LCD Component Replacement: step 9, image 1 of 3 Canon ZR70MC LCD Component Replacement: step 9, image 2 of 3 Canon ZR70MC LCD Component Replacement: step 9, image 3 of 3
      • Turn the LCD monitor so that the screen is facing down.
      • There is a 2.7 mm screw on the LCD monitor where the monitor is connected to the main body of the camcorder. Remove the 2.7 mm screw.
      Ask FixBot
    3. Canon ZR70MC LCD Component Replacement: step 10, image 1 of 2 Canon ZR70MC LCD Component Replacement: step 10, image 2 of 2
      • Turn the LCD monitor so that the screen is facing up.
      • There is a 2.7 mm screw located where the LCD monitor is connected to the main body of the camcorder. Remove the 2.7 mm screw.
      Ask FixBot
    4. Canon ZR70MC LCD Component Replacement: step 11, image 1 of 3 Canon ZR70MC LCD Component Replacement: step 11, image 2 of 3 Canon ZR70MC LCD Component Replacement: step 11, image 3 of 3
      • Now that all the screws are removed, use the plastic opening tool to gently pry the LCD monitor case open.
      Ask FixBot
    5. Canon ZR70MC LCD Component Replacement: step 12, image 1 of 3 Canon ZR70MC LCD Component Replacement: step 12, image 2 of 3 Canon ZR70MC LCD Component Replacement: step 12, image 3 of 3
      Buy
      • Use tweezers to remove the wire connections that hold the LCD screen in place.
      • Remove the entire LCD screen.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
khalid clarke
824 Reputation
7 Guides authored
USF Tampa, Team S13-G2, Boczar Fall 2017 Member of USF Tampa, Team S13-G2, Boczar Fall 2017
USFT-BOCZAR-F17S13G2
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 27
All Time: 503
