Canon Vixia HF R600 Power Button Replacement
    1. Canon Vixia HF R600 Power Button Replacement, Handstrap: step 1, image 1 of 2 Canon Vixia HF R600 Power Button Replacement, Handstrap: step 1, image 2 of 2
      • Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
      • If you are adjusting the hand-strap, tighten or loosen the Velcro strap accordingly and reattach it.
      • To remove the hand-strap, pull the Velcro strip through the leather pad.
      Ask FixBot
    2. Canon Vixia HF R600 Power Button Replacement: step 2, image 1 of 2 Canon Vixia HF R600 Power Button Replacement: step 2, image 2 of 2
      • Remove the strap from the camera body.
      Ask FixBot
    1. Canon Vixia HF R600 Power Button Replacement, Battery: step 3, image 1 of 2 Canon Vixia HF R600 Power Button Replacement, Battery: step 3, image 2 of 2
      • Press in the battery release tab located on the bottom of the camera.
      • Slide the battery out from the body.
      Ask FixBot
    1. Canon Vixia HF R600 Power Button Replacement, Casing: step 4, image 1 of 2 Canon Vixia HF R600 Power Button Replacement, Casing: step 4, image 2 of 2
      • Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
      • Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
      Ask FixBot
    2. Canon Vixia HF R600 Power Button Replacement: step 5, image 1 of 2 Canon Vixia HF R600 Power Button Replacement: step 5, image 2 of 2
      • Open the display screen and remove the three 5mm Phillips #00 screws.
      • Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
      Ask FixBot
    3. Canon Vixia HF R600 Power Button Replacement: step 6, image 1 of 2 Canon Vixia HF R600 Power Button Replacement: step 6, image 2 of 2
      • Gently pull the plastic casing away from the camera.
      Ask FixBot
    1. Canon Vixia HF R600 Power Button Replacement, Speaker: step 7, image 1 of 2 Canon Vixia HF R600 Power Button Replacement, Speaker: step 7, image 2 of 2
      • Remove one 4mm Phillips JIS#00 screw on the right side of the camera.
      • Use the plastic opening tool to undo the bronze ribbon connector.
      Ask FixBot
    2. Canon Vixia HF R600 Power Button Replacement: step 8, image 1 of 2 Canon Vixia HF R600 Power Button Replacement: step 8, image 2 of 2
      • Remove one 4mm Phillips JIS#00 screw located on the top of the camera near the battery connection.
      • Pull the plastic casing away from the camera. The speaker and power button are housed in this casing.
      Ask FixBot
    3. Canon Vixia HF R600 Power Button Replacement: step 9, image 1 of 2 Canon Vixia HF R600 Power Button Replacement: step 9, image 2 of 2
      • Remove four 5mm Phillips PH#00 screws holding the speaker bracket in place.
      • Remove one more 5mm screw below the power button.
      Ask FixBot
    4. Canon Vixia HF R600 Power Button Replacement: step 10, image 1 of 2 Canon Vixia HF R600 Power Button Replacement: step 10, image 2 of 2
      • Carefully pull the speaker out of the casing.
      Ask FixBot
    1. Canon Vixia HF R600 Power Button Replacement, Power Button: step 11, image 1 of 2 Canon Vixia HF R600 Power Button Replacement, Power Button: step 11, image 2 of 2
      Tool used on this step:
      Buy
      • Using a pair of tweezers, gently push in the red tabs of the power button.
      • Pull the power button out of the camera casing.
      Ask FixBot
Brian Luna
483 Reputation
4 Guides authored
USF Tampa, Team 14-4, Lacy Spring 2016 Member of USF Tampa, Team 14-4, Lacy Spring 2016
USFT-LACY-S16S14G4
3 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 26
All Time: 691
