Up to 20% off select tools
Canon Speedlite 430EX II Diffusing Disc Panel Replacement
Views: 9.3K
View statistics:
Past 24 Hours:
8
Past 7 Days:
27
Past 30 Days:
126
All Time:
9,266
Comments: 5
5 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
    1. Canon Speedlite 430EX II Diffusing Disc Panel Replacement, Diffusing Disc Panel: step 1, image 1 of 2 Canon Speedlite 430EX II Diffusing Disc Panel Replacement, Diffusing Disc Panel: step 1, image 2 of 2
      • At first of all: Remove Batteries!
      • Be Careful: Electronic parts need a few minutes to discharge. If you touch them you may get an electric shock or damage your device.
      Ask FixBot
    2. Canon Speedlite 430EX II Diffusing Disc Panel Replacement, Remove covers: step 2, image 1 of 2 Canon Speedlite 430EX II Diffusing Disc Panel Replacement, Remove covers: step 2, image 2 of 2
      • Open the silicone covers slowly. The're fixed with double faced adhesive tape.
      • In the worst case: You damage the covers. It's very hard to damage the flash at this step
      Ask FixBot
    3. Canon Speedlite 430EX II Diffusing Disc Panel Replacement, Open the flash head: step 3, image 1 of 3 Canon Speedlite 430EX II Diffusing Disc Panel Replacement, Open the flash head: step 3, image 2 of 3 Canon Speedlite 430EX II Diffusing Disc Panel Replacement, Open the flash head: step 3, image 3 of 3
      • Remove the screws on the bottom of the flash-head
      • Remove all 8 screws which holds the outer case on the joint.
      • Separate the screws from each other - that makes the re-assembling easier
      Ask FixBot
    4. Canon Speedlite 430EX II Diffusing Disc Panel Replacement, Remove the flash Unit: step 4, image 1 of 2 Canon Speedlite 430EX II Diffusing Disc Panel Replacement, Remove the flash Unit: step 4, image 2 of 2
      • Open the head slowly - attention with the cables
      • Remove the flash unit
      • Remember: Electric parts!
      • Remember the order of the diffusing discs
      Ask FixBot
    5. Canon Speedlite 430EX II Diffusing Disc Panel Replacement, Replace the mechanism: step 5, image 1 of 3 Canon Speedlite 430EX II Diffusing Disc Panel Replacement, Replace the mechanism: step 5, image 2 of 3 Canon Speedlite 430EX II Diffusing Disc Panel Replacement, Replace the mechanism: step 5, image 3 of 3
      • Remove the 4 screws of the holding plate.
      • You need to remove the plastic film - don't worry you can stick it back when you're ready and it holds fine.
      • The thing in the square is the contact which detects if the panel is in or out.
      Ask FixBot
    6. Canon Speedlite 430EX II Diffusing Disc Panel Replacement: step 6, image 1 of 3 Canon Speedlite 430EX II Diffusing Disc Panel Replacement: step 6, image 2 of 3 Canon Speedlite 430EX II Diffusing Disc Panel Replacement: step 6, image 3 of 3
      • Now you're ready to install the panel
      • Hold it in the position (just to check that everything is correct and fit in the head.
      • Now you need to re-assemble backwards. Careful with the cables
      Ask FixBot
    7. Canon Speedlite 430EX II Diffusing Disc Panel Replacement, Reassemble: step 7, image 1 of 3 Canon Speedlite 430EX II Diffusing Disc Panel Replacement, Reassemble: step 7, image 2 of 3 Canon Speedlite 430EX II Diffusing Disc Panel Replacement, Reassemble: step 7, image 3 of 3
      • Hold the diffusing discs while you plug the top and bottom together
      • stick a little piece of double faced adhesive tape to the silicone covers
      • Both covers have those tiny silicone pins and the fitting hole for alignment
      Ask FixBot
I hope this guide is helpful enough.
If you have any questions feel free to contact me.
12 other people completed this guide.
Author
with
spark
491 Reputation
1 Guide authored
5 Guide Comments
Great guide! Thank you so much for helping me fix my flash! I didn't need additional adhesive tape as it went back with the remainders of the original one and seems to hold up well. I would highly recommend using magnetic screwdriver as I had issues with those small screws going back into the tiny places they belong to. Otherwise, it was an easy fix!
PS watch out for that push button. It has a tendency to jump out :)
ritafoigel - Reply Share
Thanks a lot. I can only agree with the comment on magnetic screwdrivers.
Also, notice that there are two types of screws: flat head and countersunk head. They also differ slightly in length.
I had a lot of trouble with wires getting stuck but a few tries and some care help.
Further, when assembling the push button and the rotating mechanisms I needed to pay attention to two tiny taps that fit into one of the two clamshells.
Finally, the tiny switch sensing the diffusing disc panel needed to be seated in two holes. I managed to assemble the flash only to discover that the sensing didn't work.
I hope these comments will help others.
chrmikkelsen - Reply Share
Oh my gosh..I can't believe I actually did this..when I got the cover off, the 'push' button and spring popped off. I thought I just ought to quit while I was barely ahead. I did take it all apart- the instructions were fabulous-the screws I put in ordered piles...apparently they're not the same. I replaced the diffuser panel..it only really goes one way..put all screws back- replaced the batteries, and wa la- it worked. THANK YOU a million times over. Pam
Pam Dose - Reply Share
Absolutely outstanding guide! The only way it could have been easier is if you were doing it for me. As others have said, watch for the push button popping out. It took me a minute to find the spring... Thanks!
L Burk - Reply Share
Thank you. Easy to do with this instruction.
peterroehl - Reply Share
Past 24 Hours: 8
Past 7 Days: 27
Past 30 Days: 126
All Time: 9,266
