Canon Selphy CP910 Printer Body Replacement
    1. Canon Selphy CP910 Printer Body Replacement, Body: step 1, image 1 of 2 Canon Selphy CP910 Printer Body Replacement, Body: step 1, image 2 of 2
      • Turn the printer over.
      • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
      • Keep track of these screws because you will need them to reassemble the printer.
      Ask FixBot
    2. Canon Selphy CP910 Printer Body Replacement: step 2, image 1 of 3 Canon Selphy CP910 Printer Body Replacement: step 2, image 2 of 3 Canon Selphy CP910 Printer Body Replacement: step 2, image 3 of 3
      • Loosen up the four 10 mm corner screws.
      • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
      Ask FixBot
    3. Canon Selphy CP910 Printer Body Replacement: step 3, image 1 of 3 Canon Selphy CP910 Printer Body Replacement: step 3, image 2 of 3 Canon Selphy CP910 Printer Body Replacement: step 3, image 3 of 3
      • Turn the device around and remove the "open" lid.
      • This lid needs to be removed in order to take the printer apart.
      • Gently bend the lid and remove it from its hinges.
      Ask FixBot
    4. Canon Selphy CP910 Printer Body Replacement: step 4, image 1 of 3 Canon Selphy CP910 Printer Body Replacement: step 4, image 2 of 3 Canon Selphy CP910 Printer Body Replacement: step 4, image 3 of 3
      • Turn the device back over and lift the top panel up.
      • Disconnect the ribbon cables leading to the LCD screen.
      • Pull the top panel off.
      Ask FixBot
    1. Canon Selphy CP910 Printer Body Replacement, Printer Body: step 5, image 1 of 2 Canon Selphy CP910 Printer Body Replacement, Printer Body: step 5, image 2 of 2
      • Use the PH1 screw driver to remove the three screws on the motherboard.
      Ask FixBot
    2. Canon Selphy CP910 Printer Body Replacement: step 6, image 1 of 2 Canon Selphy CP910 Printer Body Replacement: step 6, image 2 of 2
      • Remove the printer.
      • This will prevent the printer from falling out during repair.
      Ask FixBot
    3. Canon Selphy CP910 Printer Body Replacement: step 7, image 1 of 3 Canon Selphy CP910 Printer Body Replacement: step 7, image 2 of 3 Canon Selphy CP910 Printer Body Replacement: step 7, image 3 of 3
      • Remove the output connections.
      • Be careful! Do not pull too hard because the wires might rip.
      • Output connections are located on the corners of the motherboard.
      Ask FixBot
    4. Canon Selphy CP910 Printer Body Replacement: step 8, image 1 of 2 Canon Selphy CP910 Printer Body Replacement: step 8, image 2 of 2
      • The motherboard is attached to three more ribbon wires.
      • Detach these wires.
      • Be careful not to pull too hard.
      Ask FixBot
    5. Canon Selphy CP910 Printer Body Replacement: step 9, image 1 of 2 Canon Selphy CP910 Printer Body Replacement: step 9, image 2 of 2
      • Separate the motherboard from the main hard drive.
      Ask FixBot
    6. Canon Selphy CP910 Printer Body Replacement: step 10, image 1 of 3 Canon Selphy CP910 Printer Body Replacement: step 10, image 2 of 3 Canon Selphy CP910 Printer Body Replacement: step 10, image 3 of 3
      • Remove the main hard drive from the printer body.
      Ask FixBot
    7. Canon Selphy CP910 Printer Body Replacement: step 11, image 1 of 2 Canon Selphy CP910 Printer Body Replacement: step 11, image 2 of 2
      • Gently remove the fan from the body.
      • The fan is glued to the case. When you install it in the new body, use hot glue to secure it in place.
      Ask FixBot
    8. Canon Selphy CP910 Printer Body Replacement: step 12, image 1 of 2 Canon Selphy CP910 Printer Body Replacement: step 12, image 2 of 2
      • The empty case will look like this once all the parts are removed.
      Ask FixBot
4 other people completed this guide.
Christie Peralta
751 Reputation
5 Guides authored
UW Tacoma, Team 1-6, Rose Winter 2016 Member of UW Tacoma, Team 1-6, Rose Winter 2016
UWT-ROSE-W16S1G6
4 Members
60 Guides authored
1 Guide Comment
Bien conduit par cette marche à suivre, j'ai réussi à démonter la cartouche bloquée suite à un disfonctionnement des photos .
Le remontage était un peu plus difficile suite à la minutie à apporter auprès du peu de place pour la reconnection. Merci.
Joël vanhooren - Reply Share
Past 24 Hours: 4
Past 7 Days: 40
Past 30 Days: 169
All Time: 6,446
