Up to 20% off select tools
Canon Selphy CP910 Buttons Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
109
All Time:
1,609
Comments: 3
3 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The Canon Selphy CP910 is used to print pictures from a camera and WiFi connection. If there are any issues with the buttons on the printer, it may be necessary to remove them. For information regarding troubleshooting issues with the Canon Selphy CP910, go to Canon Selphy CP910 Troubleshooting.
Contact the manufacturer for inquiries about receiving parts of the Canon Selphy CP910.
    1. Canon Selphy CP910 Buttons Replacement, Body: step 1, image 1 of 2 Canon Selphy CP910 Buttons Replacement, Body: step 1, image 2 of 2
      • Turn the printer over.
      • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
      • Keep track of these screws because you will need them to reassemble the printer.
      Ask FixBot
    2. Canon Selphy CP910 Buttons Replacement: step 2, image 1 of 3 Canon Selphy CP910 Buttons Replacement: step 2, image 2 of 3 Canon Selphy CP910 Buttons Replacement: step 2, image 3 of 3
      • Loosen up the four 10 mm corner screws.
      • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
      Ask FixBot
    3. Canon Selphy CP910 Buttons Replacement: step 3, image 1 of 3 Canon Selphy CP910 Buttons Replacement: step 3, image 2 of 3 Canon Selphy CP910 Buttons Replacement: step 3, image 3 of 3
      • Turn the device around and remove the "open" lid.
      • This lid needs to be removed in order to take the printer apart.
      • Gently bend the lid and remove it from its hinges.
      Ask FixBot
    4. Canon Selphy CP910 Buttons Replacement: step 4, image 1 of 3 Canon Selphy CP910 Buttons Replacement: step 4, image 2 of 3 Canon Selphy CP910 Buttons Replacement: step 4, image 3 of 3
      • Turn the device back over and lift the top panel up.
      • Disconnect the ribbon cables leading to the LCD screen.
      • Pull the top panel off.
      Ask FixBot
    1. Canon Selphy CP910 Buttons Replacement, Buttons: step 5, image 1 of 2 Canon Selphy CP910 Buttons Replacement, Buttons: step 5, image 2 of 2
      • Turn the top panel over so the inside faces toward you.
      Ask FixBot
    2. Canon Selphy CP910 Buttons Replacement: step 6, image 1 of 3 Canon Selphy CP910 Buttons Replacement: step 6, image 2 of 3 Canon Selphy CP910 Buttons Replacement: step 6, image 3 of 3
      • Use the PH0 screw bit to remove the five 10 mm screws located above the circuit board.
      Ask FixBot
    3. Canon Selphy CP910 Buttons Replacement: step 7, image 1 of 2 Canon Selphy CP910 Buttons Replacement: step 7, image 2 of 2
      • Carefully remove the frame attached to the screen.
      Ask FixBot
    4. Canon Selphy CP910 Buttons Replacement: step 8, image 1 of 3 Canon Selphy CP910 Buttons Replacement: step 8, image 2 of 3 Canon Selphy CP910 Buttons Replacement: step 8, image 3 of 3
      • Take out the circuit board.
      • Once you take out the circuit board, you should be left with just the case.
      Ask FixBot
    5. Canon Selphy CP910 Buttons Replacement: step 9, image 1 of 2 Canon Selphy CP910 Buttons Replacement: step 9, image 2 of 2
      • There is a clear plastic ā€œLā€ shaped piece that acts as the power light for the printer. The piece is not attached to the printer so take care not to lose it.
      • Remove the button framework and replace it with new one.
      Ask FixBot
Author
with
Christie Peralta
763 Reputation
5 Guides authored
UW Tacoma, Team 1-6, Rose Winter 2016 Member of UW Tacoma, Team 1-6, Rose Winter 2016
UWT-ROSE-W16S1G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 109
All Time: 1,609
