Canon Selphy CP1200 Cooling Fan Replacement
  1. Canon Selphy CP1200 Cooling Fan Replacement, LCD/Buttons: step 1, image 1 of 1
    • Unscrew the four 6mm PH000 corner screws.
    • This will require a screwdriver with a long, narrow shaft.
    Ask FixBot
  2. Canon Selphy CP1200 Cooling Fan Replacement: step 2, image 1 of 1
    • Unscrew the three 4mm PH1 screws on the bottom of the printer.
    Ask FixBot
  3. Canon Selphy CP1200 Cooling Fan Replacement: step 3, image 1 of 1
    • Gently pry open the top of the case from either the front or back.
    • A plastic opening tool may help.
    • Be careful in lifting the top assembly as it is attached to the motherboard at this point.
    Ask FixBot
  4. Canon Selphy CP1200 Cooling Fan Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
    • Tweezers may be useful given the limited space between the top assembly and motherboard.
    • The top assembly, containing both the LCD and buttons, will now be completely free
    Ask FixBot
  5. Canon Selphy CP1200 Cooling Fan Replacement, Motherboard: step 5, image 1 of 1
    • Detach the fan cable from the motherboard.
    Ask FixBot
  6. Canon Selphy CP1200 Cooling Fan Replacement: step 6, image 1 of 1
    Buy
    • Detach the ribbon cable leading to the DC in port and battery leads.
    • Tweezers may be useful.
    Ask FixBot
  7. Canon Selphy CP1200 Cooling Fan Replacement: step 7, image 1 of 1
    • Unscrew the three 3mm PH000 screws from the motherboard.
    Ask FixBot
  8. Canon Selphy CP1200 Cooling Fan Replacement: step 8, image 1 of 1
    • Disconnect the bundled cables leading to the printing mechanism.
    Ask FixBot
  9. Canon Selphy CP1200 Cooling Fan Replacement: step 9, image 1 of 1
    • Gently lift the motherboard and detach the ribbon cables leading to the print mechanism.
    • Tweezers may be useful due to the limited amount of space.
    Ask FixBot
  10. Canon Selphy CP1200 Cooling Fan Replacement, Print Mechanism: step 10, image 1 of 2 Canon Selphy CP1200 Cooling Fan Replacement, Print Mechanism: step 10, image 2 of 2
    • Open the side door and depress the ink cassette release.
    • Slide out and remove the ink cassette.
    Ask FixBot
  11. Canon Selphy CP1200 Cooling Fan Replacement: step 11, image 1 of 1
    • Unscrew the three 3mm PH000 screws securing the metal plate to the printing mechanism.
    Ask FixBot
  12. Canon Selphy CP1200 Cooling Fan Replacement: step 12, image 1 of 1
    • Lift out the print mechanism of the printer case.
    Ask FixBot
  13. Canon Selphy CP1200 Cooling Fan Replacement, Cooling Fan: step 13, image 1 of 1
    • Lift out the back case plate.
    Ask FixBot
  14. Canon Selphy CP1200 Cooling Fan Replacement: step 14, image 1 of 2 Canon Selphy CP1200 Cooling Fan Replacement: step 14, image 2 of 2
    • Remove the fan by tilting it forward slightly and then lifting upwards.
    Ask FixBot
1 Guide Comment
Where can I get a new cooling fan for Selphy 1200
Roy johannessen - Reply Share
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 34
All Time: 692
