Canon SX40 HS camera Flash Cover Replacement
    1. Canon SX40 HS camera Flash Cover Replacement, Flash Cover: step 1, image 1 of 2 Canon SX40 HS camera Flash Cover Replacement, Flash Cover: step 1, image 2 of 2
      • Extend the flash cover upwards and remove the 4 mm black screw located on the left side. You will need a Phillips #00 screwdriver to remove it.
      • Repeat to remove the 4 mm black screw located on the right side.
      Ask FixBot
    2. Canon SX40 HS camera Flash Cover Replacement: step 2, image 1 of 1
      • Remove the plastic cover using the iFixIt Plastic Opening Tool.
      • The plastic cover can only be removed in the down position.
      Ask FixBot
    3. Canon SX40 HS camera Flash Cover Replacement: step 3, image 1 of 2 Canon SX40 HS camera Flash Cover Replacement: step 3, image 2 of 2
      • After removing the flash cover, remove the 6 mm silver screw on the right side with a Phillips #00 screwdriver.
      • Repeat to remove the 6 mm silver screw on the left side with a Phillips #00 screwdriver.
      Ask FixBot
    4. Canon SX40 HS camera Flash Cover Replacement: step 4, image 1 of 1
      • Replace the external flash cover or the internal flashlight when all 6 mm silver screws are out.
      Ask FixBot
To reassemble your device, follow Steps 1-4 in reverse order.
John Bui
352 Reputation
3 Guides authored
2 Guide Comments
How to disconnect wires from front cover to remove it.
Pete Gubbels - Reply Share
Has anyone tried to remove the front cover from their sx40?
Mine has a bundle of 4 wires going to some sensor below where the flash is. Looks like there’s a clear plastic sensor there but I can’t figure out how to disconnect them.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 38
All Time: 1,247
