Canon Rebel T5i Back Cover Replacement
    1. Canon Rebel T5i Back Cover Replacement, Back Cover: step 1, image 1 of 2 Canon Rebel T5i Back Cover Replacement, Back Cover: step 1, image 2 of 2
      • Before beginning, remove the battery and SD card from the camera.
      • Using your thumbs, push up on the eyepiece to remove it.
      • Remove the battery door.
      • Open the battery door to about a 35° angle.
      • Pull the battery door straight outwards.
      Ask FixBot
    2. Canon Rebel T5i Back Cover Replacement: step 2, image 1 of 3 Canon Rebel T5i Back Cover Replacement: step 2, image 2 of 3 Canon Rebel T5i Back Cover Replacement: step 2, image 3 of 3
      • Peel back the left rubber grip using a plastic opening pick.
      • Underneath the grip, remove the following screws:
      • Four M1.7x5.0mm T6 Torx screws
      • On the right side of the camera, remove the following screws:
      • One M1.7x5.5mm JIS #000 screw
      • One M1.7x3.5mm JIS #000 screw
      Ask FixBot
    3. Canon Rebel T5i Back Cover Replacement: step 3, image 1 of 2 Canon Rebel T5i Back Cover Replacement: step 3, image 2 of 2
      • On the bottom of the camera, remove the following screws:
      • One M1.7x6.0mm JIS #000 screw
      • Two M1.7x3.0mm JIS #000 screws
      • On the back of the camera, remove the following screws:
      Ask FixBot
    4. Canon Rebel T5i Back Cover Replacement: step 4, image 1 of 3 Canon Rebel T5i Back Cover Replacement: step 4, image 2 of 3 Canon Rebel T5i Back Cover Replacement: step 4, image 3 of 3
      • Using a plastic opening pick, partially peel up the top of the back rubber grip.
      • Carefully begin lifting the back cover up away from the camera body.
      • Do not lift it all the way off. There is still a ribbon cable attaching the back cover to the main PCB board.
      • Use a plastic spudger to gently pry off the ribbon cable.
      • Use a plastic spudger to gently pry off the other cable connecting the back cover to the camera.
      • The connector tab sticks out slightly on each end of the connector, which gives you a good spot to pry the connector off.
      Ask FixBot
Attached Documents
Zephosk
6,057 Reputation
39 Guides authored
LGBTQ Technicians Member of LGBTQ Technicians
Community
67 Members
848 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 68
All Time: 913
