Canon Powershot SD880 Top Panel Replacement
    1. Canon Powershot SD880 Top Panel Replacement, Back Cover: step 1, image 1 of 3 Canon Powershot SD880 Top Panel Replacement, Back Cover: step 1, image 2 of 3 Canon Powershot SD880 Top Panel Replacement, Back Cover: step 1, image 3 of 3
      • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
      • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
      • One screw will be located under the rubber USB flap.
      • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
      • Slowly pull the back cover off of the camera.
      Ask FixBot
    1. Canon Powershot SD880 Top Panel Replacement, Top Panel: step 2, image 1 of 2 Canon Powershot SD880 Top Panel Replacement, Top Panel: step 2, image 2 of 2
      • Unplug the green and white plugs that connect the top panel to the top of the logic board.
      • Dislodge the tab above the lens.
      • Dislodge the tab at the back.
      Ask FixBot
Robert Manno
444 Reputation
4 Guides authored
Cal Poly, Team 13-3, Forte Winter 2011 Member of Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 17
Past 30 Days: 42
All Time: 1,476
