Canon Powershot SD880 LCD Display Replacement
  1. Canon Powershot SD880 LCD Display Replacement, Back Cover: step 1, image 1 of 3 Canon Powershot SD880 LCD Display Replacement, Back Cover: step 1, image 2 of 3 Canon Powershot SD880 LCD Display Replacement, Back Cover: step 1, image 3 of 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
    Ask FixBot
  2. Canon Powershot SD880 LCD Display Replacement, LCD Display: step 2, image 1 of 3 Canon Powershot SD880 LCD Display Replacement, LCD Display: step 2, image 2 of 3 Canon Powershot SD880 LCD Display Replacement, LCD Display: step 2, image 3 of 3
    • Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
    • Disconnect the ribbons that connect the screen to the camera.
    • Lift the screen off.
    Ask FixBot
Ben Tupas
329 Reputation
3 Guides authored
Cal Poly, Team 13-3, Forte Winter 2011 Member of Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Members
8 Guides authored
1 Guide Comment
Hm. "Disconnect the ribbons" resulted in a torn ribbon, and so a dead camera, I think. This also doesn't say how to take the LCD screen out of its frame. Alas.
Maelduin - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 38
All Time: 2,808
