Canon Powershot SD880 Flash Replacement
  1. Canon Powershot SD880 Flash Replacement, Back Cover: step 1, image 1 of 3 Canon Powershot SD880 Flash Replacement, Back Cover: step 1, image 2 of 3 Canon Powershot SD880 Flash Replacement, Back Cover: step 1, image 3 of 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
    Ask FixBot
  2. Canon Powershot SD880 Flash Replacement, Front Cover: step 2, image 1 of 3 Canon Powershot SD880 Flash Replacement, Front Cover: step 2, image 2 of 3 Canon Powershot SD880 Flash Replacement, Front Cover: step 2, image 3 of 3
    • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
    • The two screws on the other side of the camera were already removed when the back cover was taken off.
    Ask FixBot
  3. Canon Powershot SD880 Flash Replacement, Top Panel: step 3, image 1 of 2 Canon Powershot SD880 Flash Replacement, Top Panel: step 3, image 2 of 2
    • Unplug the green and white plugs that connect the top panel to the top of the logic board.
    • Dislodge the tab above the lens.
    • Dislodge the tab at the back.
    Ask FixBot
  4. Canon Powershot SD880 Flash Replacement, LCD Display: step 4, image 1 of 3 Canon Powershot SD880 Flash Replacement, LCD Display: step 4, image 2 of 3 Canon Powershot SD880 Flash Replacement, LCD Display: step 4, image 3 of 3
    • Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
    • Disconnect the ribbons that connect the screen to the camera.
    • Lift the screen off.
    Ask FixBot
  5. Canon Powershot SD880 Flash Replacement, Flash: step 5, image 1 of 3 Canon Powershot SD880 Flash Replacement, Flash: step 5, image 2 of 3 Canon Powershot SD880 Flash Replacement, Flash: step 5, image 3 of 3
    • Use caution when removing the flash, as the capacitor may still have a charge.
    • Remove two 1.8 mm screws from the back using a Phillips #0 screwdriver to disconnect the metal guard.
    • To unplug the ribbon at the top of the camera, gently pull it from the plug-in point.
    • Disconnect the white plug from the red and black wires.
    Ask FixBot
Robert Manno
444 Reputation
4 Guides authored
Cal Poly, Team 13-3, Forte Winter 2011 Member of Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 42
All Time: 3,010
