Canon Powershot SD790 IS Disassembly
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Canon Powershot SD790 IS Disassembly, Canon Powershot SD790 IS: step 1, image 1 of 3 Canon Powershot SD790 IS Disassembly, Canon Powershot SD790 IS: step 1, image 2 of 3 Canon Powershot SD790 IS Disassembly, Canon Powershot SD790 IS: step 1, image 3 of 3
    • 1. Use a Phillips #0 screwdriver to remove the six screws from the sides of the camera. 2. Hold the mini-USB cover open. Gently grip and remove the side cover. 3. Grip the camera from the sides and carefully remove the screen cover.
    Ask FixBot
  2. Canon Powershot SD790 IS Disassembly: step 2, image 1 of 2 Canon Powershot SD790 IS Disassembly: step 2, image 2 of 2
    • Hold the mini-USB cover open.
    • Gently grip and remove the side cover.
    Ask FixBot
  3. Canon Powershot SD790 IS Disassembly: step 3, image 1 of 3 Canon Powershot SD790 IS Disassembly: step 3, image 2 of 3 Canon Powershot SD790 IS Disassembly: step 3, image 3 of 3
    • Grip the camera from the sides and carefully remove the screen cover.
    • Start at the bottom edge and slowly lift up the cover.
    • Be very careful removing the cover in the area with the camera/video switch.
    • Remove the front cover while continuing to grip the sides of the camera.
    • After removing the screen cover, remove the screw by the power switch that anchors the side plate to separate the sides from the camera.
    Ask FixBot
3 other people completed this guide.
Stanley
393 Reputation
4 Guides authored
Cal Poly, Team 4-33, Regan Winter 2011 Member of Cal Poly, Team 4-33, Regan Winter 2011
CPSU-REGAN-W11S4G33
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 32
All Time: 5,647
