Canon Powershot SD750 Camera Case Replacement
    1. Canon Powershot SD750 Camera Case Replacement, Camera Case: step 1, image 1 of 1
      • Turn the camera to the side that has the attachment for the wrist strap.
      • Unscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
      Ask FixBot
    2. Canon Powershot SD750 Camera Case Replacement: step 2, image 1 of 1
      • Remove the plastic subsection by prying it with your fingers.
      • Note: It may be helpful to pry from the bottom of the camera with the battery door open.
      • The wrist strap attachment behind the subsection will come loose and may fall out.
      Ask FixBot
    3. Canon Powershot SD750 Camera Case Replacement: step 3, image 1 of 1
      • Turn the camera over to the side opposite of the wrist strap.
      • Remove the two silver 3.4 mm screws with a #00 Phillips screwdriver.
      Ask FixBot
    4. Canon Powershot SD750 Camera Case Replacement: step 4, image 1 of 1
      • Flip the camera upside down.
      • Remove the following screws with a #00 Phillips screwdriver.
      • One black 3.4 mm Phillips screw.
      • One silver 3.4 mm Phillips screw.
      • NOTE: Using your fingernails may help in removal.
      Ask FixBot
    5. Canon Powershot SD750 Camera Case Replacement: step 5, image 1 of 1
      • Place the camera on the side opposite of the wrist strap handle.
      • Then begin to pry the casing apart with both hands by applying pressure to the top and bottom of the camera.
      • Remove the small metal plate underneath the plastic covering and set aside. (It should be loosely attached)
      • Note: A rubber foam washer that separates the lens from the casing will fall off when the case is removed. Be sure to store it safely.
      • Note: When reassembling ensure the back plate screw tabs are over the wrist strap attachment and the front plate screw tabs go under orange casing.
      Ask FixBot
5 other people completed this guide.
Memphis Wong
73 Reputation
1 Guide authored
Cal Poly, Team 14-37, Forte Fall 2010 Member of Cal Poly, Team 14-37, Forte Fall 2010
CPSU-FORTE-F10S14G37
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 47
All Time: 4,463
