Canon Powershot SD550 Shutter Button Replacement
    1. Canon Powershot SD550 Shutter Button Replacement, Outer Case: step 1, image 1 of 1
      • Remove the battery and SD card from the camera.
      Ask FixBot
    2. Canon Powershot SD550 Shutter Button Replacement: step 2, image 1 of 1
      • Remove the three 3.8 mm screws from the underside of the camera.
      • Each of the screws is slightly different, so it is important that you note the original location of each screw.
      Ask FixBot
    3. Canon Powershot SD550 Shutter Button Replacement: step 3, image 1 of 3 Canon Powershot SD550 Shutter Button Replacement: step 3, image 2 of 3 Canon Powershot SD550 Shutter Button Replacement: step 3, image 3 of 3
      • Remove the 3.2 mm screw from the right side of the camera.
      • Remove the 2.2 mm screw from the right side of the camera.
      • One of these screws is hidden under the USB port cover.
      • Lift the side panel off.
      • Remove the 1.8 mm screw from underneath the side panel.
      Ask FixBot
    4. Canon Powershot SD550 Shutter Button Replacement: step 4, image 1 of 3 Canon Powershot SD550 Shutter Button Replacement: step 4, image 2 of 3 Canon Powershot SD550 Shutter Button Replacement: step 4, image 3 of 3
      • Remove the two 2.2 mm screws from the left side of the camera.
      • Lift the plate from the camera.
      Ask FixBot
    5. Canon Powershot SD550 Shutter Button Replacement: step 5, image 1 of 3 Canon Powershot SD550 Shutter Button Replacement: step 5, image 2 of 3 Canon Powershot SD550 Shutter Button Replacement: step 5, image 3 of 3
      • Gently lift the rear of the case to remove it from the camera.
      Ask FixBot
    6. Canon Powershot SD550 Shutter Button Replacement: step 6, image 1 of 3 Canon Powershot SD550 Shutter Button Replacement: step 6, image 2 of 3 Canon Powershot SD550 Shutter Button Replacement: step 6, image 3 of 3
      • Remove the front of the camera body.
      • Be sure to keep track of the rubber ring.
      Ask FixBot
    1. Canon Powershot SD550 Shutter Button Replacement, Shutter Button: step 7, image 1 of 2 Canon Powershot SD550 Shutter Button Replacement, Shutter Button: step 7, image 2 of 2
      • Next, unscrew the .115 inch screw fastening the shutter button to the camera.
      • Now lift the button away from the camera, exposing the button board.
      • You have successfully removed the shutter button.
      Ask FixBot
Ken Michael
1 Reputation
1 Guide authored
Cal Poly, Team 18-23, Garner Spring 2011 Member of Cal Poly, Team 18-23, Garner Spring 2011
CPSU-GARNER-S11S18G23
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 12
All Time: 1,847
