Canon Powershot SD550 Image Sensor Replacement
    1. Canon Powershot SD550 Image Sensor Replacement, Outer Case: step 1, image 1 of 1
      • Remove the battery and SD card from the camera.
      Ask FixBot
    2. Canon Powershot SD550 Image Sensor Replacement: step 2, image 1 of 1
      • Remove the three 3.8 mm screws from the underside of the camera.
      • Each of the screws is slightly different, so it is important that you note the original location of each screw.
      Ask FixBot
    3. Canon Powershot SD550 Image Sensor Replacement: step 3, image 1 of 3 Canon Powershot SD550 Image Sensor Replacement: step 3, image 2 of 3 Canon Powershot SD550 Image Sensor Replacement: step 3, image 3 of 3
      • Remove the 3.2 mm screw from the right side of the camera.
      • Remove the 2.2 mm screw from the right side of the camera.
      • One of these screws is hidden under the USB port cover.
      • Lift the side panel off.
      • Remove the 1.8 mm screw from underneath the side panel.
      Ask FixBot
    4. Canon Powershot SD550 Image Sensor Replacement: step 4, image 1 of 3 Canon Powershot SD550 Image Sensor Replacement: step 4, image 2 of 3 Canon Powershot SD550 Image Sensor Replacement: step 4, image 3 of 3
      • Remove the two 2.2 mm screws from the left side of the camera.
      • Lift the plate from the camera.
      Ask FixBot
    5. Canon Powershot SD550 Image Sensor Replacement: step 5, image 1 of 3 Canon Powershot SD550 Image Sensor Replacement: step 5, image 2 of 3 Canon Powershot SD550 Image Sensor Replacement: step 5, image 3 of 3
      • Gently lift the rear of the case to remove it from the camera.
      Ask FixBot
    6. Canon Powershot SD550 Image Sensor Replacement: step 6, image 1 of 3 Canon Powershot SD550 Image Sensor Replacement: step 6, image 2 of 3 Canon Powershot SD550 Image Sensor Replacement: step 6, image 3 of 3
      • Remove the front of the camera body.
      • Be sure to keep track of the rubber ring.
      Ask FixBot
    1. Canon Powershot SD550 Image Sensor Replacement, LCD Screen: step 7, image 1 of 3 Canon Powershot SD550 Image Sensor Replacement, LCD Screen: step 7, image 2 of 3 Canon Powershot SD550 Image Sensor Replacement, LCD Screen: step 7, image 3 of 3
      • Peel the navigation buttons from the button panel and set them aside.
      • To free the LCD display, remove the 2.9 mm screw in the top left corner.
      • Rotate the screen clockwise until it lifts away from the camera.
      • There are two ribbon cables attached to the rear of the screen. Do not try to pull the screen off at this point.
      Ask FixBot
    2. Canon Powershot SD550 Image Sensor Replacement: step 8, image 1 of 2 Canon Powershot SD550 Image Sensor Replacement: step 8, image 2 of 2
      • To unplug the ribbon cables, pull them straight out of their plugs. Do this gently to avoid damaging the connections.
      • After disconnecting both cables, pull the screen away from the camera to remove it.
      Ask FixBot
    1. Canon Powershot SD550 Image Sensor Replacement, Image Sensor: step 9, image 1 of 2 Canon Powershot SD550 Image Sensor Replacement, Image Sensor: step 9, image 2 of 2
      • Now the photo sensor is exposed. In order to remove the ribbon cable from its port, first flip up the blue locking mechanism.
      • After the cable is unlocked, it easily pulls free.
      Ask FixBot
    2. Canon Powershot SD550 Image Sensor Replacement: step 10, image 1 of 2 Canon Powershot SD550 Image Sensor Replacement: step 10, image 2 of 2
      • In order to remove the photo sensor, you will have to cut through glue and remove screws.
      • Use a knife to carefully slice through the glue at the tree points indicated. Try not to cut through anything but the glue to avoid damage.
      • WARNING: Knives are sharp. Treat them with respect.
      • Now remove the three .15 inch screws holding the photo sensor to the camera frame.
      Ask FixBot
    3. Canon Powershot SD550 Image Sensor Replacement: step 11, image 1 of 2 Canon Powershot SD550 Image Sensor Replacement: step 11, image 2 of 2
      • Now you can carefully lift up the image sensor and remove it from the camera.
      • Be careful not to lose the three small springs or the rubber grommet that lie beneath the sensor.
      Ask FixBot
    4. Canon Powershot SD550 Image Sensor Replacement: step 12, image 1 of 1
      • You have now successfully removed the image sensor.
      Ask FixBot
3 other people completed this guide.
Matthew Theiss
191 Reputation
3 Guides authored
Cal Poly, Team 18-23, Garner Spring 2011 Member of Cal Poly, Team 18-23, Garner Spring 2011
CPSU-GARNER-S11S18G23
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 36
All Time: 3,301
