Canon Powershot S410 Memory Card Replacement
  1. Canon Powershot S410 Memory Card Replacement, Battery: step 1, image 1 of 2 Canon Powershot S410 Memory Card Replacement, Battery: step 1, image 2 of 2
    • Turn the camera with the bottom side facing up.
    • Locate the panel labeled "Batt. Open"
    • Place your finger on the panel and slide it in the direction of the arrow.
    • The slot will swing open revealing the battery pack.
    Ask FixBot
  2. Canon Powershot S410 Memory Card Replacement: step 2, image 1 of 1
    • Pull the orange lever and the battery will spring out slightly.
    Ask FixBot
  3. Canon Powershot S410 Memory Card Replacement: step 3, image 1 of 2 Canon Powershot S410 Memory Card Replacement: step 3, image 2 of 2
    • Grasp the battery and fully pull it out of its slot.
    • When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
    Ask FixBot
  4. Canon Powershot S410 Memory Card Replacement, Memory Card: step 4, image 1 of 2 Canon Powershot S410 Memory Card Replacement, Memory Card: step 4, image 2 of 2
    • Position the camera as if you were going to take a picture.
    • Locate the sliding button labeled "CF OPEN."
    • Place your finger on the button and slide it in the direction of the arrow.
    • The side panel will flip open revealing the compact flash memory card.
    Ask FixBot
  5. Canon Powershot S410 Memory Card Replacement: step 5, image 1 of 1
    • Turn the camera to the right side.
    • Locate the gray button at the bottom of the open slot.
    • Place your finger on the button and push it down.
    • The memory card will pop out slightly.
    Ask FixBot
  6. Canon Powershot S410 Memory Card Replacement: step 6, image 1 of 1
    • Grasp edges of card and pull out of slot.
    • If you insert a new memory card you may be asked to format it after turning on the camera.
    • Make sure that the arrow on the flash card is pointed towards the direction of the slot
    • Do not force the memory card into the slot. Any signs of resistance may mean the card is improperly oriented.
    Ask FixBot
Once a new memory card has been inserted close the swinging door and you're done.
Randy Lormand
349 Reputation
3 Guides authored
Cal Poly, Team 11-27, Maness Winter 2011 Member of Cal Poly, Team 11-27, Maness Winter 2011
CPSU-MANESS-W11S11G27
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 45
All Time: 2,610
