Canon Powershot S200 Screen Replacement
  1. Canon Powershot S200 Screen Replacement, Battery: step 1, image 1 of 2 Canon Powershot S200 Screen Replacement, Battery: step 1, image 2 of 2
    • Slide the grey latch to open the battery compartment.
    Ask FixBot
  2. Canon Powershot S200 Screen Replacement: step 2, image 1 of 2 Canon Powershot S200 Screen Replacement: step 2, image 2 of 2
    • Push and slide the orange retaining clip to the right to remove the battery.
    Ask FixBot
  3. Canon Powershot S200 Screen Replacement: step 3, image 1 of 1
    • Remove battery from the camera.
    Ask FixBot
  4. Canon Powershot S200 Screen Replacement, Motherboard: step 4, image 1 of 1
    • Remove the lanyard.
    Ask FixBot
  5. Canon Powershot S200 Screen Replacement: step 5, image 1 of 1
    • Position the camera so that the bottom is facing up.
    • Remove the two 2.3mm screws beneath the name plate.
    • Remove the two 2.8 mm screws surrounding the threaded tripod mount.
    Ask FixBot
  6. Canon Powershot S200 Screen Replacement: step 6, image 1 of 1
    • Remove the 3.8mm screw from the back face of the camera.
    Ask FixBot
  7. Canon Powershot S200 Screen Replacement: step 7, image 1 of 1
    • Remove the two 2.3mm screws from the right face of the camera.
    Ask FixBot
  8. Canon Powershot S200 Screen Replacement: step 8, image 1 of 1
    • Remove the two outer 3.2mm screws from the left side of the camera
    • Remove the two inner 3.7mm screws from the left side of the camera.
    Ask FixBot
  9. Canon Powershot S200 Screen Replacement: step 9, image 1 of 1
    • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
    Ask FixBot
  10. Canon Powershot S200 Screen Replacement: step 10, image 1 of 2 Canon Powershot S200 Screen Replacement: step 10, image 2 of 2
    • Remove the CF card door from the left side of the camera body.
    Ask FixBot
  11. Canon Powershot S200 Screen Replacement: step 11, image 1 of 2 Canon Powershot S200 Screen Replacement: step 11, image 2 of 2
    • Slide the rubber digital a/v cap out of place on the front plate.
    Ask FixBot
  12. Canon Powershot S200 Screen Replacement: step 12, image 1 of 1
    • Remove the front face by sliding it off.
    Ask FixBot
  13. Canon Powershot S200 Screen Replacement: step 13, image 1 of 1
    • Remove the rubber seal that covers the right side of the viewfinder.
    Ask FixBot
  14. Canon Powershot S200 Screen Replacement: step 14, image 1 of 1
    • Remove the two 3.9mm screws that hold the laminated copper sheet.
    Ask FixBot
  15. Canon Powershot S200 Screen Replacement: step 15, image 1 of 2 Canon Powershot S200 Screen Replacement: step 15, image 2 of 2
    • Remove the wire connections that connect along the bottom of the motherboard.
    Ask FixBot
  16. Canon Powershot S200 Screen Replacement: step 16, image 1 of 1
    • Remove the single 3.8mm screw that is on the motherboard.
    Ask FixBot
  17. Canon Powershot S200 Screen Replacement: step 17, image 1 of 1
    • Remove the motherboard from the main frame of the camera body.
    Ask FixBot
  18. Canon Powershot S200 Screen Replacement, Screen: step 18, image 1 of 1
    • After completing the removal of the motherboard, remove the tripod mounting screws (3.4mm) on the left side
    Ask FixBot
  19. Canon Powershot S200 Screen Replacement: step 19, image 1 of 1
    • Carefully pry the left side of the housing plate from the bottom of the tripod mounting plate, releasing it from the two alignment pegs next to the screws
    Ask FixBot
  20. Canon Powershot S200 Screen Replacement: step 20, image 1 of 1
    • Lift the left side of the tripod mounting plate towards you, lift free the mounting plate from the rest of the assembly
    • Be careful because there are still wire connections attached to the mounting plate which you don't want to remove
    Ask FixBot
  21. Canon Powershot S200 Screen Replacement: step 21, image 1 of 1
    • Remove the 2.1mm screws from the bottom and top of the screen connecting it to the housing plate
    Ask FixBot
  22. Canon Powershot S200 Screen Replacement: step 22, image 1 of 1
    • Unsolder the four points at the top of the screen with a soldering iron
    Ask FixBot
Anh
148 Reputation
1 Guide authored
Cal Poly, Team 20-70, Walters Spring 2011 Member of Cal Poly, Team 20-70, Walters Spring 2011
CPSU-WALTERS-S11S20G70
5 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 28
All Time: 1,947
