Canon Powershot Pro1 Lens Replacement
    1. Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: step 1, image 1 of 2 Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: step 1, image 2 of 2
      • Have the lens of the camera facing upwards.
      • Find the red plastic ring.
      • Look for two small opening above the red plastic ring.
      • Reference to the left of the picture and you will see the orange square.
      Ask FixBot
    2. Canon Powershot Pro1 Lens Replacement: step 2, image 1 of 3 Canon Powershot Pro1 Lens Replacement: step 2, image 2 of 3 Canon Powershot Pro1 Lens Replacement: step 2, image 3 of 3
      • Remove the plastic ring that has a red strip.
      • Remove the 1.5 mm Phillips #1 screws which lie underneath the ring.
      Ask FixBot
    3. Canon Powershot Pro1 Lens Replacement: step 3, image 1 of 3 Canon Powershot Pro1 Lens Replacement: step 3, image 2 of 3 Canon Powershot Pro1 Lens Replacement: step 3, image 3 of 3
      • Place the camera on its back with the lens facing upwards as shown in the image
      • Remove the additional 1.5 mm Phillip #1 screw from underneath the lens cover
      • Remove the screw by turning the Philip driver counterclockwise.
      • By removing the screw, you will be able to remove the cover lens.
      Ask FixBot
    4. Canon Powershot Pro1 Lens Replacement: step 4, image 1 of 1
      • Use the nylon spudger to remove the ring holding the lens in place.
      • Pull gently until the lens ring snaps off.
      Ask FixBot
    5. Canon Powershot Pro1 Lens Replacement: step 5, image 1 of 1
      • Refer to the left-hand pictere to see what the len's ring looks like.
      Ask FixBot
    6. Canon Powershot Pro1 Lens Replacement: step 6, image 1 of 3 Canon Powershot Pro1 Lens Replacement: step 6, image 2 of 3 Canon Powershot Pro1 Lens Replacement: step 6, image 3 of 3
      • Take out the lens once the plastic ring is removed
      • Hold the outer layer of the lens to not create smudges on it.
      • Replace the lens and follow the instruction in reversed order to reassemble the camera.
      Ask FixBot
1 Guide Comment
Hi, can you do a guide on how to repair the diaphragm?
OTVaL - Reply Share
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 71
All Time: 4,112
