Canon Powershot A95 Flash Unit Replacement
    1. Canon Powershot A95 Flash Unit Replacement, Flash Unit: step 1, image 1 of 3 Canon Powershot A95 Flash Unit Replacement, Flash Unit: step 1, image 2 of 3 Canon Powershot A95 Flash Unit Replacement, Flash Unit: step 1, image 3 of 3
      • Have a small Phillips-head screwdriver and extender, an opening tool, and a soldering iron to complete the following steps.
      • Keep the screws organized and separated as you remove them.
      Ask FixBot
    2. Canon Powershot A95 Flash Unit Replacement: step 2, image 1 of 1
      • Locate the memory card slot on the far right with the screen facing toward you.
      • Remove the memory card.
      Ask FixBot
    3. Canon Powershot A95 Flash Unit Replacement: step 3, image 1 of 2 Canon Powershot A95 Flash Unit Replacement: step 3, image 2 of 2
      • With the screen facing toward you, the battery slot can be found under the right side of the camera.
      • Remove all batteries and leave the slot open.
      Ask FixBot
    4. Canon Powershot A95 Flash Unit Replacement: step 4, image 1 of 3 Canon Powershot A95 Flash Unit Replacement: step 4, image 2 of 3 Canon Powershot A95 Flash Unit Replacement: step 4, image 3 of 3
      • There are two screws to the right of the battery slot.
      • Take the #00 Phillips-head screwdriver and remove the two screws.
      Ask FixBot
    5. Canon Powershot A95 Flash Unit Replacement: step 5, image 1 of 2 Canon Powershot A95 Flash Unit Replacement: step 5, image 2 of 2
      • Inside the battery slot, there are another 3 screws located at the very bottom of each slot.
      • To reach these screws and remove them, attach the screwdriver extender to the #00 Phillips-head screwdriver.
      Ask FixBot
    6. Canon Powershot A95 Flash Unit Replacement: step 6, image 1 of 2 Canon Powershot A95 Flash Unit Replacement: step 6, image 2 of 2
      • At the base of the battery flap, there are 2 screws located next to the hinges of the opening.
      • Remove both screws.
      Ask FixBot
    7. Canon Powershot A95 Flash Unit Replacement: step 7, image 1 of 2 Canon Powershot A95 Flash Unit Replacement: step 7, image 2 of 2
      • Using the pry tool, pry the top of the camera open.
      • Be sure not to apply too much force and damage the wires under the lid.
      • The top should dangle loosely from the camera and not be fully detached.
      Ask FixBot
    8. Canon Powershot A95 Flash Unit Replacement: step 8, image 1 of 2 Canon Powershot A95 Flash Unit Replacement: step 8, image 2 of 2
      • Once the top is loose, locate the 2 screws near the AV outlet.
      • The removal of the 2 screws will allow you to remove the plastic AV covering.
      • Once the AV cover is removed, there will be 1 more screw left to remove.
      Ask FixBot
    9. Canon Powershot A95 Flash Unit Replacement: step 9, image 1 of 2 Canon Powershot A95 Flash Unit Replacement: step 9, image 2 of 2
      • Using the pry tool, gently remove the front cover of the camera in order to expose the flash and the lens.
      Ask FixBot
    10. Canon Powershot A95 Flash Unit Replacement: step 10, image 1 of 2 Canon Powershot A95 Flash Unit Replacement: step 10, image 2 of 2
      • Locate the black film under the flash unit and remove the screw holding it in place.
      • Once the screw is removed, gently wiggle the flash out of place without damaging any internal parts.
      Ask FixBot
    11. Canon Powershot A95 Flash Unit Replacement: step 11, image 1 of 2 Canon Powershot A95 Flash Unit Replacement: step 11, image 2 of 2
      • There will be a second black film which is covering the flash wires.
      • Remove the film to reveal the wires.
      Ask FixBot
    12. Canon Powershot A95 Flash Unit Replacement: step 12, image 1 of 1
      • Once the second film is removed and has revealed the flash wires, proceed to unsolder the necessary wires in order to detach the flash.
      • Take the new flash and solder it where the old one was removed.
      Ask FixBot
To reassemble, follow the disassemble steps in reverse order.
Amber
3 Reputation
1 Guide authored
Ohio State, Team 1-4, Buehl Spring 2013 Member of Ohio State, Team 1-4, Buehl Spring 2013
OSU-BUEHL-S13S1G4
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 32
All Time: 1,403
