Canon PowerShot SX620 HS LCD Screen Replacement
  1. Canon PowerShot SX620 HS LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • Open the battery door located on the bottom of the camera.
    • Push the orange tab until the battery springs upwards and out.
    • Remove the battery from the camera.
    Ask FixBot
  2. Canon PowerShot SX620 HS LCD Screen Replacement: step 2, image 1 of 2 Canon PowerShot SX620 HS LCD Screen Replacement: step 2, image 2 of 2
    • Remove the two 4 mm screws from the side of the camera with the flash assembly using a Phillips #000 screwdriver
    • Make sure to keep your screws from different steps separate.
    Ask FixBot
  3. Canon PowerShot SX620 HS LCD Screen Replacement: step 3, image 1 of 2 Canon PowerShot SX620 HS LCD Screen Replacement: step 3, image 2 of 2
    • Remove the four 2 mm screws from the bottom of the camera using a Phillips #000 screwdriver.
    Ask FixBot
  4. Canon PowerShot SX620 HS LCD Screen Replacement: step 4, image 1 of 2 Canon PowerShot SX620 HS LCD Screen Replacement: step 4, image 2 of 2
    • Remove the single 4 mm screw from the other side of the camera using a Phillips #000 screwdriver.
    Ask FixBot
  5. Canon PowerShot SX620 HS LCD Screen Replacement: step 5, image 1 of 2 Canon PowerShot SX620 HS LCD Screen Replacement: step 5, image 2 of 2
    • Open the HDMI cover.
    • Remove the single 4 mm screw inside the HDMI cover using a Phillips #000 screwdriver.
    Ask FixBot
  6. Canon PowerShot SX620 HS LCD Screen Replacement: step 6, image 1 of 3 Canon PowerShot SX620 HS LCD Screen Replacement: step 6, image 2 of 3 Canon PowerShot SX620 HS LCD Screen Replacement: step 6, image 3 of 3
    • Use a plastic opening tool at the top of the camera to loosen the back piece of the outer case. Once it is loose, pull it straight out.
    • Use the same technique to remove the front piece of the camera case.
    Ask FixBot
  7. Canon PowerShot SX620 HS LCD Screen Replacement: step 7, image 1 of 3 Canon PowerShot SX620 HS LCD Screen Replacement: step 7, image 2 of 3 Canon PowerShot SX620 HS LCD Screen Replacement: step 7, image 3 of 3
    • Place the camera with the LCD screen facing up.
    • Pull the side cover pieces out.
    Ask FixBot
  8. Canon PowerShot SX620 HS LCD Screen Replacement: step 8, image 1 of 1
    • Flip the camera over so the lens is facing upwards.
    • Use the Phillips #000 screwdriver to remove the screw located near the photo button.
    Ask FixBot
  9. Canon PowerShot SX620 HS LCD Screen Replacement: step 9, image 1 of 2 Canon PowerShot SX620 HS LCD Screen Replacement: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Detach the orange connector from the lens piece using tweezers.
    • Be extremely careful with any of these connectors. They are very fragile and contain important electronic components. If one is damaged, your camera will not work at all.
    Ask FixBot
  10. Canon PowerShot SX620 HS LCD Screen Replacement: step 10, image 1 of 2 Canon PowerShot SX620 HS LCD Screen Replacement: step 10, image 2 of 2
    • Grab the top cover piece directly above the lens. Pull upward to remove it from the camera body.
    Ask FixBot
  11. Canon PowerShot SX620 HS LCD Screen Replacement: step 11, image 1 of 2 Canon PowerShot SX620 HS LCD Screen Replacement: step 11, image 2 of 2
    • Use the Phillips #000 screwdriver to remove the two 2 mm screws from the button panel.
    Ask FixBot
  12. Canon PowerShot SX620 HS LCD Screen Replacement: step 12, image 1 of 3 Canon PowerShot SX620 HS LCD Screen Replacement: step 12, image 2 of 3 Canon PowerShot SX620 HS LCD Screen Replacement: step 12, image 3 of 3
    • Use tweezers to carefully detach the connector that is hidden underneath the button panel.
    • Be careful not to damage anything on the motherboard underneath.
    • Flip the button panel upward.
    Ask FixBot
  13. Canon PowerShot SX620 HS LCD Screen Replacement: step 13, image 1 of 3 Canon PowerShot SX620 HS LCD Screen Replacement: step 13, image 2 of 3 Canon PowerShot SX620 HS LCD Screen Replacement: step 13, image 3 of 3
    • Flip the small black cover upward so you can remove the large orange connector. Carefully remove this connector and the smaller connector holding the LCD screen in place.
    • Lift the LCD screen out of the metal frame.
    Ask FixBot
3 other people completed this guide.
2 Guide Comments
How did you reattach the button panel connector once you had flipped it back down?
beep - Reply Share
Est-ce que cet écran peut remplacer celui d'un SX620HS
Claude SX620 HS - Reply Share
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 193
All Time: 4,992
