Canon PowerShot SX530 HS Lens Replacement
  1. Canon PowerShot SX530 HS Lens Replacement, Battery: step 1, image 1 of 1
    • Flip the camera upside down to find the battery compartment (marked CARD/ BATT. OPEN).
    • Press into the grooves of the battery door and slide the panel in the direction of the arrow.
    Ask FixBot
  2. Canon PowerShot SX530 HS Lens Replacement: step 2, image 1 of 1
    • Gently press down on the orange release button found inside.
    • After pressing the release button, pull the battery out of the camera.
    Ask FixBot
  3. Canon PowerShot SX530 HS Lens Replacement, Canon PowerShot SX530 HS Back Panel Assembly: step 3, image 1 of 2 Canon PowerShot SX530 HS Lens Replacement, Canon PowerShot SX530 HS Back Panel Assembly: step 3, image 2 of 2
    • Flip over the camera.
    • Use a Phillips PH000 to remove the two 4mm screws near the center of the camera.
    • Use a Phillips PH000 to remove the two 6mm screws on the ends of the camera.
    Ask FixBot
  4. Canon PowerShot SX530 HS Lens Replacement: step 4, image 1 of 2 Canon PowerShot SX530 HS Lens Replacement: step 4, image 2 of 2
    • Locate the left side of the camera.
    • Use a Philips PH000 to remove the two 6mm screws.
    Ask FixBot
  5. Canon PowerShot SX530 HS Lens Replacement: step 5, image 1 of 2 Canon PowerShot SX530 HS Lens Replacement: step 5, image 2 of 2
    • Rotate the camera to the side with the removable cover containing the HDMI and mini USB ports.
    • Use the Phillips PH000 to remove the 7mm screw located next to the HDMI port. This screw has red loctite.
    • Use the Phillips PH000 to remove the 4mm screw near the USB port.
    • Use the Phillips PH000 to remove the 7.4mm screw near the USB port.
    Ask FixBot
  6. Canon PowerShot SX530 HS Lens Replacement: step 6, image 1 of 3 Canon PowerShot SX530 HS Lens Replacement: step 6, image 2 of 3 Canon PowerShot SX530 HS Lens Replacement: step 6, image 3 of 3
    • Rotate the camera to locate the side with the LCD screen.
    • Use a Phillips PH000 to remove the two 6mm screws above the LCD screen.
    • Once the screws are out the back panel, it is ready to be taken off. Grip the backside of the camera and pull it away evenly on every side. The backside must come off straight from the front.
    Ask FixBot
  7. Canon PowerShot SX530 HS Lens Replacement, Shutter Back Cover: step 7, image 1 of 1
    • Remove the two screws (5-6mm) on the left and right side of the shutter panel with a Phillips PH000 screwdriver.
    Ask FixBot
  8. Canon PowerShot SX530 HS Lens Replacement: step 8, image 1 of 1
    • Lift the shutter light and pull the shutter back panel off the camera.
    • Be careful when pulling out the panel because it is connected to the motherboard.
    Ask FixBot
  9. Canon PowerShot SX530 HS Lens Replacement, Internal Button Sensor Plate: step 9, image 1 of 2 Canon PowerShot SX530 HS Lens Replacement, Internal Button Sensor Plate: step 9, image 2 of 2
    • Locate the Internal Button Sensor Plate. This is the white and silver plate to the right of the LCD Display.
    • Use a Phillips PH000 to remove the two 3mm screws on the panel.
    • Use a Phillips PH000 to remove the 3mm screw connected to the motherboard.
    Ask FixBot
  10. Canon PowerShot SX530 HS Lens Replacement: step 10, image 1 of 2 Canon PowerShot SX530 HS Lens Replacement: step 10, image 2 of 2
    • Peel off the plate. Be careful, as the plate is connected to the motherboard underneath by a ribbon.
    • Use a plastic opening tool to unlock the ribbon tape.
    • Remove the ribbon tape from the motherboard.
    Ask FixBot
  11. Canon PowerShot SX530 HS Lens Replacement, LCD Display: step 11, image 1 of 2 Canon PowerShot SX530 HS Lens Replacement, LCD Display: step 11, image 2 of 2
    • Locate the Display screen in the center of the camera.
    • Use a plastic opening tool to pry off the LCD screen. Start on the bottom left corner—this is the furthest away from the ribbon holding it down on the right side.
    • The adhesive holding down the display should be strong enough to put the display back on.
    Ask FixBot
  12. Canon PowerShot SX530 HS Lens Replacement: step 12, image 1 of 1
    Ask FixBot
  13. Canon PowerShot SX530 HS Lens Replacement, Shutter Release Cover: step 13, image 1 of 3 Canon PowerShot SX530 HS Lens Replacement, Shutter Release Cover: step 13, image 2 of 3 Canon PowerShot SX530 HS Lens Replacement, Shutter Release Cover: step 13, image 3 of 3
    • Hold the camera by the bottom or place the camera on a firm flat surface and keep a firm grip on the device.
    • Once a comfortable hold is established, gently pull the cover towards the rear of the camera. Then lift directly upwards on the cover to remove it.
    • Do not pull the cover off too hard to the point that you might accidentally tug on the ribbon tape.
    Ask FixBot
  14. Canon PowerShot SX530 HS Lens Replacement: step 14, image 1 of 1
    • Once the cover is loose from the device, use a plastic opening tool to unlock the ribbon tape.
    Ask FixBot
  15. Canon PowerShot SX530 HS Lens Replacement, Internal Metal Frame: step 15, image 1 of 2 Canon PowerShot SX530 HS Lens Replacement, Internal Metal Frame: step 15, image 2 of 2
    • Use a PH000 screwdriver to remove the four 3.5 mm screws holding the plate in place.
    • Use a PH000 screwdriver to remove the two 2.5 mm screws holding the top of the plate.
    • Use a PH000 screwdriver to remove the two 4.5 mm screws connecting the plate to the motherboard.
    Ask FixBot
  16. Canon PowerShot SX530 HS Lens Replacement: step 16, image 1 of 1
    • Gently pull the plate up and away from the camera.
    • Part of the plate extends inside the camera beneath the shutter, so be sure to not angle the plate as you pull.
    Ask FixBot
  17. Canon PowerShot SX530 HS Lens Replacement, Lens: step 17, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to pull the large ribbon cable connecting the back of the lens to the motherboard.
    Ask FixBot
  18. Canon PowerShot SX530 HS Lens Replacement: step 18, image 1 of 1
    Ask FixBot
  19. Canon PowerShot SX530 HS Lens Replacement: step 19, image 1 of 1
    • Pull the lens partly away from the camera to reveal another ribbon cable connecting the lens to the motherboard.
    Ask FixBot
  20. Canon PowerShot SX530 HS Lens Replacement: step 20, image 1 of 1
    • Pull the lens, the entire piece to the left of the motherboard, out of the camera.
    Ask FixBot
  21. Canon PowerShot SX530 HS Lens Replacement, Further Troubleshooting: step 21, image 1 of 1
    • Follow this lens replacement video for further dissection of the lens. Continue if lens is fine.
    • Remove the six 3.5mm screws to remove the motherboard from the lens.
    • There are another 3 parts inside the lens that will need realignment upon reassembly. The motor's worm gear will line up with the rack on the outer assembly.
    • Ensure lens is able to move and rotate for reassembly.
    Ask FixBot
4 other people completed this guide.
Joel groff
335 Reputation
2 Guides authored
USF Tampa, Team 16-4, Blackwell Spring 2017 Member of USF Tampa, Team 16-4, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G4
4 Members
9 Guides authored
4 Guide Comments
where do you get a replacement lens?
cjborcharles - Reply Share
Aren’t steps 15 and 16 already done as steps 11 and 12?
William John Goetzinger - Reply Share
Any more repair instructions on the internals of the actual lens?
John Donovan - Reply Share
Thank you SOOOO much for posting this. I found your guide after I had the camera mostly disassembled. I was able to use your photos in place of one's I missed and put the camera back together. The lens somehow got stuck and wouldn't zoom. After disassembling the lens and putting it back on the tracks the camera now works. Great job on the guide. Thank you.
Keyboard Man - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 79
All Time: 10,235
