Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement
  1. Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement, Battery: step 1, image 1 of 1
    • Flip the camera upside down to find the battery compartment (marked CARD/ BATT. OPEN).
    • Press into the grooves of the battery door and slide the panel in the direction of the arrow.
    Ask FixBot
  2. Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: step 2, image 1 of 1
    • Gently press down on the orange release button found inside.
    • After pressing the release button, pull the battery out of the camera.
    Ask FixBot
  3. Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement, Canon PowerShot SX530 HS Back Panel Assembly: step 3, image 1 of 2 Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement, Canon PowerShot SX530 HS Back Panel Assembly: step 3, image 2 of 2
    • Flip over the camera.
    • Use a Phillips PH000 to remove the two 4mm screws near the center of the camera.
    • Use a Phillips PH000 to remove the two 6mm screws on the ends of the camera.
    Ask FixBot
  4. Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: step 4, image 1 of 2 Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: step 4, image 2 of 2
    • Locate the left side of the camera.
    • Use a Philips PH000 to remove the two 6mm screws.
    Ask FixBot
  5. Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: step 5, image 1 of 2 Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: step 5, image 2 of 2
    • Rotate the camera to the side with the removable cover containing the HDMI and mini USB ports.
    • Use the Phillips PH000 to remove the 7mm screw located next to the HDMI port. This screw has red loctite.
    • Use the Phillips PH000 to remove the 4mm screw near the USB port.
    • Use the Phillips PH000 to remove the 7.4mm screw near the USB port.
    Ask FixBot
  6. Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: step 6, image 1 of 3 Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: step 6, image 2 of 3 Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: step 6, image 3 of 3
    • Rotate the camera to locate the side with the LCD screen.
    • Use a Phillips PH000 to remove the two 6mm screws above the LCD screen.
    • Once the screws are out the back panel, it is ready to be taken off. Grip the backside of the camera and pull it away evenly on every side. The backside must come off straight from the front.
    Ask FixBot
  7. Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement, Internal Button Sensor Plate: step 7, image 1 of 2 Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement, Internal Button Sensor Plate: step 7, image 2 of 2
    • Locate the Internal Button Sensor Plate. This is the white and silver plate to the right of the LCD Display.
    • Use a Phillips PH000 to remove the two 3mm screws on the panel.
    • Use a Phillips PH000 to remove the 3mm screw connected to the motherboard.
    Ask FixBot
  8. Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: step 8, image 1 of 2 Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: step 8, image 2 of 2
    • Peel off the plate. Be careful, as the plate is connected to the motherboard underneath by a ribbon.
    • Use a plastic opening tool to unlock the ribbon tape.
    • Remove the ribbon tape from the motherboard.
    Ask FixBot
Xavier Patrick
488 Reputation
3 Guides authored
USF Tampa, Team 16-4, Blackwell Spring 2017 Member of USF Tampa, Team 16-4, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G4
4 Members
9 Guides authored
1 Guide Comment
Przy najkrótszych śrubkach jest problem zich wyjęciem z otworu. POtrzebny śrubokręt z namagnesowanym czubkiem.
Ryszard Lasocki - Reply Share
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 48
All Time: 1,305
