Canon PowerShot SX520 HS Metal Plate Replacement
  1. Canon PowerShot SX520 HS Metal Plate Replacement, Back Face: step 1, image 1 of 3 Canon PowerShot SX520 HS Metal Plate Replacement, Back Face: step 1, image 2 of 3 Canon PowerShot SX520 HS Metal Plate Replacement, Back Face: step 1, image 3 of 3
    • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
    Ask FixBot
  2. Canon PowerShot SX520 HS Metal Plate Replacement: step 2, image 1 of 1
    • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
    Ask FixBot
  3. Canon PowerShot SX520 HS Metal Plate Replacement: step 3, image 1 of 2 Canon PowerShot SX520 HS Metal Plate Replacement: step 3, image 2 of 2
    • Pull back the rubber facing to access the A/V and HDMI output compartment.
    • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
    Ask FixBot
  4. Canon PowerShot SX520 HS Metal Plate Replacement: step 4, image 1 of 1
    • Once all screws are removed, pull the back facing off with your fingers.
    Ask FixBot
  5. Canon PowerShot SX520 HS Metal Plate Replacement, LCD Screen: step 5, image 1 of 1
    • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
    Ask FixBot
  6. Canon PowerShot SX520 HS Metal Plate Replacement: step 6, image 1 of 1
    • Carefully pop out the LCD screen with your fingers.
    Ask FixBot
  7. Canon PowerShot SX520 HS Metal Plate Replacement, Metal Plate: step 7, image 1 of 3 Canon PowerShot SX520 HS Metal Plate Replacement, Metal Plate: step 7, image 2 of 3 Canon PowerShot SX520 HS Metal Plate Replacement, Metal Plate: step 7, image 3 of 3
    • Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
    • Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • After all 8 screws are removed, pull the metal plate out with your fingers.
    Ask FixBot
Lisa Choe
460 Reputation
3 Guides authored
Baylor, Team 4-4, Williams Fall 2015 Member of Baylor, Team 4-4, Williams Fall 2015
BU-WILLIAMS-F15S4G4
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 19
All Time: 439
