Canon PowerShot SX520 HS LCD Screen Replacement
    1. Canon PowerShot SX520 HS LCD Screen Replacement, Battery: step 1, image 1 of 1
      • Using your fingers, slide the battery compartment door to the right until it unlocks.
      Ask FixBot
    2. Canon PowerShot SX520 HS LCD Screen Replacement: step 2, image 1 of 1
      • Rotate the door along hinges to open.
      • Take out the battery with your fingers.
      Ask FixBot
    1. Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: step 3, image 1 of 3 Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: step 3, image 2 of 3 Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: step 3, image 3 of 3
      • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
      • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
      Ask FixBot
    2. Canon PowerShot SX520 HS LCD Screen Replacement: step 4, image 1 of 1
      • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
      Ask FixBot
    3. Canon PowerShot SX520 HS LCD Screen Replacement: step 5, image 1 of 2 Canon PowerShot SX520 HS LCD Screen Replacement: step 5, image 2 of 2
      • Pull back the rubber facing to access the A/V and HDMI output compartment.
      • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
      Ask FixBot
    4. Canon PowerShot SX520 HS LCD Screen Replacement: step 6, image 1 of 1
      • Once all screws are removed, pull the back facing off with your fingers.
      Ask FixBot
    1. Canon PowerShot SX520 HS LCD Screen Replacement, LCD Screen: step 7, image 1 of 1
      • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
      Ask FixBot
    2. Canon PowerShot SX520 HS LCD Screen Replacement: step 8, image 1 of 1
      • Carefully pop out the LCD screen with your fingers.
      Ask FixBot
Lisa Choe
460 Reputation
3 Guides authored
Baylor, Team 4-4, Williams Fall 2015 Member of Baylor, Team 4-4, Williams Fall 2015
BU-WILLIAMS-F15S4G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 100
All Time: 1,347
