Canon PowerShot SX280 HS LCD Screen Replacement
  1. Canon PowerShot SX280 HS LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • Turn off the camera and remove the battery.
    Ask FixBot
  2. Canon PowerShot SX280 HS LCD Screen Replacement: step 2, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the two 3.4 mm screws on the left side of the camera.
    Ask FixBot
  3. Canon PowerShot SX280 HS LCD Screen Replacement: step 3, image 1 of 1
    • Using the same screwdriver, remove the two 3.4 mm screws on the bottom of the camera.
    Ask FixBot
  4. Canon PowerShot SX280 HS LCD Screen Replacement: step 4, image 1 of 1
    • Lift the small plastic tab, located on the front of the camera, to remove the GPS cover.
    Ask FixBot
  5. Canon PowerShot SX280 HS LCD Screen Replacement: step 5, image 1 of 1
    • Using the same Phillips screwdriver, remove the two screws that hold the LCD screen.
    • Remove the other small tab attached to the LCD screen.
    Ask FixBot
  6. Canon PowerShot SX280 HS LCD Screen Replacement: step 6, image 1 of 1
    • When removing the plastic casting, do not pull it all the way off. Detach the small tab first and make sure nothing else is attached to the casing.
    Ask FixBot
  7. Canon PowerShot SX280 HS LCD Screen Replacement: step 7, image 1 of 1
    • To remove the tabs from the camera, remove all screws.
    • Slowly lift the screen out of the camera using the tabs.
    Ask FixBot
  8. Canon PowerShot SX280 HS LCD Screen Replacement: step 8, image 1 of 1
    • Use the tabs, outlined in red, to slowly remove the LCD screen.
    • Remove the screws to remove the camera motherboard.
    Ask FixBot
  9. Canon PowerShot SX280 HS LCD Screen Replacement: step 9, image 1 of 1
    • Insert the replacement LCD screen.
    • Ensure that the long strip is attached to the original position.
    Ask FixBot
  10. Canon PowerShot SX280 HS LCD Screen Replacement: step 10, image 1 of 1
    • To reassemble your device, follow Steps 2 to 9 in reverse order.
    Ask FixBot
Finish Line
Osmand A Munoz
228 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 51
All Time: 2,959
