Canon PowerShot SX260 HS Battery Replacement
  1. Canon PowerShot SX260 HS Battery Replacement, Battery: step 1, image 1 of 1
    • With the device fully assembled, hold the camera with both hands with the bottom of the camera facing toward you.
    Ask FixBot
  2. Canon PowerShot SX260 HS Battery Replacement: step 2, image 1 of 2 Canon PowerShot SX260 HS Battery Replacement: step 2, image 2 of 2
    • Place your right thumb on the sliding panel that is marked Card/Battery
    • Slide the panel to your right and you will hear a slight click. This is normal and you did not damage the device.
    Ask FixBot
  3. Canon PowerShot SX260 HS Battery Replacement: step 3, image 1 of 1
    • Remove your thumb from the Card/Battery panel and lift the panel 90 degrees.
    • The battery will eject slightly by the force of a spring.
    • Remove the battery and replace.
    Ask FixBot
Tyler Kelch
622 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 30
All Time: 1,558
