Canon PowerShot SX160 IS Shutter Button Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
107
All Time:
4,183
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide walks you through how to replace a shutter button on your Canon PowerShot SX160 IS by disassembling a portion of the camera to access the non operational piece.
Tools
    1. Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: step 1, image 1 of 3 Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: step 1, image 2 of 3 Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: step 1, image 3 of 3
      • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
      • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
      • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
      Ask FixBot
    2. Canon PowerShot SX160 IS Shutter Button Replacement: step 2, image 1 of 2 Canon PowerShot SX160 IS Shutter Button Replacement: step 2, image 2 of 2
      • Using your hands, gently separate the back panel from the camera.
      • Continue to pull the back panel until it completely detaches from the camera.
      Ask FixBot
    3. Canon PowerShot SX160 IS Shutter Button Replacement: step 3, image 1 of 2 Canon PowerShot SX160 IS Shutter Button Replacement: step 3, image 2 of 2
      • Use your hands to gently separate the front panel from the camera.
      • Continue to pull the front panel until it completely detaches from the camera.
      Ask FixBot
    4. Canon PowerShot SX160 IS Shutter Button Replacement: step 4, image 1 of 1
      • Locate and replace the shutter button on the front panel of the camera.
      Ask FixBot
Congratulations, you have successfully replaced your shutter button. To reassemble your device, follow these instructions in reverse order.
2 other people completed this guide.
Jamie Secretan
2,018 Reputation
6 Guides authored
2 Guide Comments
Great guide on how to replace the shutter button. Where can I get the new button?
mess857 - Reply Share
did you ever figure out where to get a new button?
christinapayne1@icloud.com - Reply Share
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 107
All Time: 4,183
