Canon PowerShot SX160 IS Format Wheel Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
75
All Time:
1,256
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
This guide walks you through how to replace a format wheel on your Canon PowerShot SX160 IS by disassembling a portion of the camera to access the non operational piece.
Tools
    1. Canon PowerShot SX160 IS Format Wheel Replacement, Format Wheel: step 1, image 1 of 2 Canon PowerShot SX160 IS Format Wheel Replacement, Format Wheel: step 1, image 2 of 2
      • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the back of the camera.
      • The screws are located directly above the LCD screen.
      Ask FixBot
    2. Canon PowerShot SX160 IS Format Wheel Replacement: step 2, image 1 of 2 Canon PowerShot SX160 IS Format Wheel Replacement: step 2, image 2 of 2
      • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the side of the camera.
      • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the bottom of the camera.
      Ask FixBot
    3. Canon PowerShot SX160 IS Format Wheel Replacement: step 3, image 1 of 2 Canon PowerShot SX160 IS Format Wheel Replacement: step 3, image 2 of 2
      • Use your hands to gently separate the back plate from the camera.
      • Slowly pull off the camera plate until it fully detaches from the camera.
      Ask FixBot
    4. Canon PowerShot SX160 IS Format Wheel Replacement: step 4, image 1 of 2 Canon PowerShot SX160 IS Format Wheel Replacement: step 4, image 2 of 2
      • Use your hands to gently separate the front plate from the camera.
      Ask FixBot
    5. Canon PowerShot SX160 IS Format Wheel Replacement: step 5, image 1 of 1
      • Locate and replace the format wheel on the front panel of the camera.
      Ask FixBot
Congratulations, you have successfully replaced your format wheel. To reassemble your device, follow these instructions in reverse order.
Jamie Secretan
2,018 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 75
All Time: 1,256
