Canon PowerShot SX150 IS Screen Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
93
All Time:
1,387
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 7 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will describe how to remove and replace the screen on your Canon PowerShot SX150 IS. This guide can be used to fix a cracked screen, or dead pixels in the screen.
Parts
Tools
    1. Canon PowerShot SX150 IS Screen Replacement, Screen: step 1, image 1 of 3 Canon PowerShot SX150 IS Screen Replacement, Screen: step 1, image 2 of 3 Canon PowerShot SX150 IS Screen Replacement, Screen: step 1, image 3 of 3
      • Remove the 2 outer 5mm screws using the size J000 screwdriver.
      • Remove the one 5mm screw on the left and the two 4mm screws on the bottom.
      • Remove the two 2mm screws located above the screen on the back of the camera.
      Ask FixBot
    2. Canon PowerShot SX150 IS Screen Replacement: step 2, image 1 of 3 Canon PowerShot SX150 IS Screen Replacement: step 2, image 2 of 3 Canon PowerShot SX150 IS Screen Replacement: step 2, image 3 of 3
      • Remove the plastic panel surrounding the screen. (it should pop off easily)
      • Remove the one 5mm screws on the right using the size J000 screw driver from the button plate. Remove the two 4mm screws on the left, then move the button plate out of the way.
      • carefully unlatch and then detach the button plat's flex ribbon from the motherboard.
      Ask FixBot
    3. Canon PowerShot SX150 IS Screen Replacement: step 3, image 1 of 1
      • Lift the flex ribbon lock gently with your finger.
      Ask FixBot
    4. Canon PowerShot SX150 IS Screen Replacement: step 4, image 1 of 2 Canon PowerShot SX150 IS Screen Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use the tweezers to carefully detach the screen’s flex ribbon from the circuit board.
      • Any small tear could ruin the flex ribbon. Be very gentle while removing it.
      Ask FixBot
    5. Canon PowerShot SX150 IS Screen Replacement: step 5, image 1 of 1
      • Remove the two 2mm screws from the bottom of the screen with the size J000 screw driver.
      Ask FixBot
    6. Canon PowerShot SX150 IS Screen Replacement: step 6, image 1 of 1
      • Lift the screen out.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 93
All Time: 1,387
