Canon PowerShot SX120 IS Control Dial Replacement
  1. Canon PowerShot SX120 IS Control Dial Replacement, Back Cover: step 1, image 1 of 1
    • Turning the camera so the screen is facing you.
    • Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
    Ask FixBot
  2. Canon PowerShot SX120 IS Control Dial Replacement: step 2, image 1 of 1
    • Put the camera with the lens facing up and turn it to the side so the DC IN A/V OUT DIGITAL is facing you.
    • Remove the single black 3.4 mm screw with a Phillips #00 screwdriver.
    Ask FixBot
  3. Canon PowerShot SX120 IS Control Dial Replacement: step 3, image 1 of 2 Canon PowerShot SX120 IS Control Dial Replacement: step 3, image 2 of 2
    • Put the camera with the lens facing up, and turn it to the side where the battery cover is located.
    • Remove the three black 3.4 mm screws with a Phillips #00 screwdriver.
    Ask FixBot
  4. Canon PowerShot SX120 IS Control Dial Replacement: step 4, image 1 of 2 Canon PowerShot SX120 IS Control Dial Replacement: step 4, image 2 of 2
    • Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
    Ask FixBot
  5. Canon PowerShot SX120 IS Control Dial Replacement: step 5, image 1 of 1
    • Put the camera with the lens facing down, and turn it to the side where the DC IN A/V OUT DIGITAL cover and the silver lanyard attachment are located.
    • Open the DC IN A/V OUT DIGITAL cover.
    Ask FixBot
  6. Canon PowerShot SX120 IS Control Dial Replacement: step 6, image 1 of 3 Canon PowerShot SX120 IS Control Dial Replacement: step 6, image 2 of 3 Canon PowerShot SX120 IS Control Dial Replacement: step 6, image 3 of 3
    • Turn the camera with the lens facing down.
    • Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened.
    • Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
    • Carefully put pressure on the opening tool so the cover can gradually open.
    • Slowly slide the opening tool along the gap and around the edge of the camera.
    • When you are dissembling the back cover, the DC IN A/V OUT DIGITAL cover will also disassemble and fall off.
    Ask FixBot
  7. Canon PowerShot SX120 IS Control Dial Replacement: step 7, image 1 of 1
    • Remove the back cover and the DC IN A/V OUT DIGITAL cover from the camera.
    Ask FixBot
  8. Canon PowerShot SX120 IS Control Dial Replacement, Control Dial: step 8, image 1 of 3 Canon PowerShot SX120 IS Control Dial Replacement, Control Dial: step 8, image 2 of 3 Canon PowerShot SX120 IS Control Dial Replacement, Control Dial: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • Carefully remove the pin underneath the dial using a pair of tweezers and set it aside.
    • Use a pair of tweezers to remove the old control dial and set the new control in the same place.
    Ask FixBot
Destiny Bretado
122 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 46
All Time: 2,046
