Canon PowerShot SD870 IS Shutter Release Button Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
101
All Time:
4,225
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Use this repair guide to remove the faulty release button from your Canon PowerShot SD870 IS.
Parts
Tools
    1. Canon PowerShot SD870 IS Shutter Release Button Replacement, Outer Case: step 1, image 1 of 1
      • Remove the wrist strap, if present.
      • Remove the lithium-ion battery.
      Ask FixBot
    2. Canon PowerShot SD870 IS Shutter Release Button Replacement: step 2, image 1 of 3 Canon PowerShot SD870 IS Shutter Release Button Replacement: step 2, image 2 of 3 Canon PowerShot SD870 IS Shutter Release Button Replacement: step 2, image 3 of 3
      • Remove the two 4 mm Phillips #00 screws on the bottom of the camera.
      • Remove the screw next to the wrist strap attachment.
      • Pull up the “A/V OUT DIGITAL” cover and remove the screw above the USB port.
      Ask FixBot
    3. Canon PowerShot SD870 IS Shutter Release Button Replacement: step 3, image 1 of 1
      • Carefully unhook the “A/V OUT DIGITAL” cover from the hinge.
      Ask FixBot
    4. Canon PowerShot SD870 IS Shutter Release Button Replacement: step 4, image 1 of 2 Canon PowerShot SD870 IS Shutter Release Button Replacement: step 4, image 2 of 2
      • Pull the front cover from the camera by using gentle upward pressure.
      Ask FixBot
    5. Canon PowerShot SD870 IS Shutter Release Button Replacement: step 5, image 1 of 2 Canon PowerShot SD870 IS Shutter Release Button Replacement: step 5, image 2 of 2
      • Remove the two Phillips #00 screws from the flat end of the camera.
      • Remove the black L-shaped side cover plate.
      • Remove the silver u-shaped retainer plate.
      Ask FixBot
    6. Canon PowerShot SD870 IS Shutter Release Button Replacement: step 6, image 1 of 1
      • Slide the back casing off.
      Ask FixBot
    1. Canon PowerShot SD870 IS Shutter Release Button Replacement, LCD: step 7, image 1 of 1
      • The first screw that needs to be removed is located on the bottom of the camera, on the left hand side.
      • Using a Phillips #00 screwdriver remove the 0.133in silver screw on the bottom left-hand side.
      Ask FixBot
    2. Canon PowerShot SD870 IS Shutter Release Button Replacement: step 8, image 1 of 2 Canon PowerShot SD870 IS Shutter Release Button Replacement: step 8, image 2 of 2
      • The second screw that needs to be removed is located on the top of the camera.
      • Using the same Phillips head screwdriver, remove the last 0.133in silver screw.
      • This will detach a silver U-shaped piece that was holding LCD screen on. Remove the piece and put it to the side.
      Ask FixBot
    3. Canon PowerShot SD870 IS Shutter Release Button Replacement: step 9, image 1 of 1
      • The LCD screen should now only be attached by the LCD data cable.
      • Lift the screen from the right side and use a small screwdriver or other small opening device to flip the black portion of the connector upward to unlock it.
      • Carefully slide the data cable out of the connector.
      • The LCD should still be connected by the backlight cable.
      Ask FixBot
    4. Canon PowerShot SD870 IS Shutter Release Button Replacement: step 10, image 1 of 2 Canon PowerShot SD870 IS Shutter Release Button Replacement: step 10, image 2 of 2
      • To remove the backlight cable, use another small opening device to unlock the backlight cable.
      • Carefully slide out the backlight cable.
      • The LCD screen should now be fully detached from the camera body.
      Ask FixBot
    5. Canon PowerShot SD870 IS Shutter Release Button Replacement: step 11, image 1 of 1
      • The LCD screen casing is connected by 4 claws located on the top and bottom on the left and right hand side.
      • Carefully disengage the claws by gently prying them off one by one.
      • Once the claws are disengaged, the back of the casing will still be connected to the front casing by the backlight cable.
      • Carefully peel the backlight cable off of the casing.
      Ask FixBot
    6. Canon PowerShot SD870 IS Shutter Release Button Replacement: step 12, image 1 of 1
      • The LCD screen and housing should now be in three pieces:
      • LCD screen
      • LCD screen frame
      • LCD screen back housing
      • The LCD screen itself can now be removed and fixed/replaced.
      Ask FixBot
    1. Canon PowerShot SD870 IS Shutter Release Button Replacement, Shutter Release Button: step 13, image 1 of 2 Canon PowerShot SD870 IS Shutter Release Button Replacement, Shutter Release Button: step 13, image 2 of 2
      • With the case and LCD screen removed, you are ready to remove the release button.
      • Begin by using the Philips #00 screwdriver to remove two silver 0.159in screws on the top and front of the camera.
      Ask FixBot
    2. Canon PowerShot SD870 IS Shutter Release Button Replacement: step 14, image 1 of 1
      • The top plastic piece holding the release button should be held on only by a red-and-black wire connector to the logic board.
      • Remove the connector from the logic board and detach the release button housing from the camera.
      Ask FixBot
    3. Canon PowerShot SD870 IS Shutter Release Button Replacement: step 15, image 1 of 2 Canon PowerShot SD870 IS Shutter Release Button Replacement: step 15, image 2 of 2
      • With the plastic housing for the release button removed from the camera, use the Philips #00 screwdriver to remove two silver 0.090in screws.
      • The release button can now be removed and fixed or replaced.
      Ask FixBot
Sam
155 Reputation
5 Guides authored
Cal Poly, Team 10-45, Garner Spring 2010 Member of Cal Poly, Team 10-45, Garner Spring 2010
CPSU-GARNER-S10S10G45
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 101
All Time: 4,225
