Canon PowerShot SD850 IS LCD Screen Replacement
  1. Canon PowerShot SD850 IS LCD Screen Replacement, Battery: step 1, image 1 of 3 Canon PowerShot SD850 IS LCD Screen Replacement, Battery: step 1, image 2 of 3 Canon PowerShot SD850 IS LCD Screen Replacement, Battery: step 1, image 3 of 3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
    Ask FixBot
  2. Canon PowerShot SD850 IS LCD Screen Replacement: step 2, image 1 of 2 Canon PowerShot SD850 IS LCD Screen Replacement: step 2, image 2 of 2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
    Ask FixBot
  3. Canon PowerShot SD850 IS LCD Screen Replacement, Case: step 3, image 1 of 2 Canon PowerShot SD850 IS LCD Screen Replacement, Case: step 3, image 2 of 2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
    Ask FixBot
  4. Canon PowerShot SD850 IS LCD Screen Replacement: step 4, image 1 of 3 Canon PowerShot SD850 IS LCD Screen Replacement: step 4, image 2 of 3 Canon PowerShot SD850 IS LCD Screen Replacement: step 4, image 3 of 3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
    Ask FixBot
  5. Canon PowerShot SD850 IS LCD Screen Replacement: step 5, image 1 of 2 Canon PowerShot SD850 IS LCD Screen Replacement: step 5, image 2 of 2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
    Ask FixBot
  6. Canon PowerShot SD850 IS LCD Screen Replacement: step 6, image 1 of 2 Canon PowerShot SD850 IS LCD Screen Replacement: step 6, image 2 of 2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
    Ask FixBot
  7. Canon PowerShot SD850 IS LCD Screen Replacement: step 7, image 1 of 1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
    Ask FixBot
  8. Canon PowerShot SD850 IS LCD Screen Replacement: step 8, image 1 of 1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
    Ask FixBot
  9. Canon PowerShot SD850 IS LCD Screen Replacement, LCD Screen: step 9, image 1 of 1
    • Remove the 1.75 mm Phillips #00 located at the top left of the LCD screen.
    Ask FixBot
  10. Canon PowerShot SD850 IS LCD Screen Replacement: step 10, image 1 of 1
    • Remove the two 3.4 mm Phillips #00 located at the bottom of the camera.
    Ask FixBot
  11. Canon PowerShot SD850 IS LCD Screen Replacement: step 11, image 1 of 2 Canon PowerShot SD850 IS LCD Screen Replacement: step 11, image 2 of 2
    • Remove the two metal frames that hold the LCD panel in place.
    Ask FixBot
  12. Canon PowerShot SD850 IS LCD Screen Replacement: step 12, image 1 of 1
    • The LCD screen should now only be attached by two LCD data cables.
    • Lift the screen from the left side and use a spudger or a small flat head screwdriver to flip the black portion of the connector upward to unlock it.
    • Carefully slide the data cable out of the connector.
    Ask FixBot
  13. Canon PowerShot SD850 IS LCD Screen Replacement: step 13, image 1 of 1
    • The LCD should still be connected by the backlight cable.
    • To remove the backlight cable, use a spudger or a small flat head screwdriver to unlock the backlight cable.
    • Carefully slide out the backlight cable.
    • The LCD screen can now be fully detached from the camera body.
    Ask FixBot
  14. Canon PowerShot SD850 IS LCD Screen Replacement: step 14, image 1 of 2 Canon PowerShot SD850 IS LCD Screen Replacement: step 14, image 2 of 2
    • The LCD screen and housing are now in three pieces:
    • LCD screen
    • LCD screen frame
    • LCD back housing
    • The LCD screen itself can now be removed and fixed/replaced.
    Ask FixBot
Peter Tran
252 Reputation
6 Guides authored
Cal Poly, Team 20-7, Maness Fall 2010 Member of Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 46
All Time: 4,779
