Canon PowerShot SD850 IS Function Set Button Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
96
All Time:
1,710
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Community-Contributed Guide
Introduction
Go to step 1 ↓
This manual is for replacing the function/set button located on the back of the camera.
Tools
    1. Canon PowerShot SD850 IS Function Set Button Replacement, Battery: step 1, image 1 of 3 Canon PowerShot SD850 IS Function Set Button Replacement, Battery: step 1, image 2 of 3 Canon PowerShot SD850 IS Function Set Button Replacement, Battery: step 1, image 3 of 3
      • Slide the light grey tab toward the edge of the camera using your fingernail.
      • Pull the light grey tab up to open the door.
      • These photos do not show the camera’s memory card or battery, which should be visible inside.
      Ask FixBot
    2. Canon PowerShot SD850 IS Function Set Button Replacement: step 2, image 1 of 2 Canon PowerShot SD850 IS Function Set Button Replacement: step 2, image 2 of 2
      • Slide the small brown tab toward the edge of the camera using your fingernail.
      • Let go of the brown tab when the battery pops up.
      • Grab battery and pull straight up to remove from holder.
      • When inserting the battery, orient it so that the terminals connect.
      Ask FixBot
    1. Canon PowerShot SD850 IS Function Set Button Replacement, Case: step 3, image 1 of 2 Canon PowerShot SD850 IS Function Set Button Replacement, Case: step 3, image 2 of 2
      • Remove the following 4 screws:
      • Two 2.8 mm Phillips #00 at the bottom of the camera.
      • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
      Ask FixBot
    2. Canon PowerShot SD850 IS Function Set Button Replacement: step 4, image 1 of 3 Canon PowerShot SD850 IS Function Set Button Replacement: step 4, image 2 of 3 Canon PowerShot SD850 IS Function Set Button Replacement: step 4, image 3 of 3
      • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
      • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
      Ask FixBot
    3. Canon PowerShot SD850 IS Function Set Button Replacement: step 5, image 1 of 2 Canon PowerShot SD850 IS Function Set Button Replacement: step 5, image 2 of 2
      • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
      • Slide light gray door and pull up to open the door.
      • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
      Ask FixBot
    4. Canon PowerShot SD850 IS Function Set Button Replacement: step 6, image 1 of 2 Canon PowerShot SD850 IS Function Set Button Replacement: step 6, image 2 of 2
      • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
      Ask FixBot
    5. Canon PowerShot SD850 IS Function Set Button Replacement: step 7, image 1 of 1
      • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
      Ask FixBot
    6. Canon PowerShot SD850 IS Function Set Button Replacement: step 8, image 1 of 1
      • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
      Ask FixBot
    1. Canon PowerShot SD850 IS Function Set Button Replacement, Function Set Button: step 9, image 1 of 2 Canon PowerShot SD850 IS Function Set Button Replacement, Function Set Button: step 9, image 2 of 2
      • Identify and remove the plastic function set button. Do this by gently prying up as indicated in the photo.
      Ask FixBot
    2. Canon PowerShot SD850 IS Function Set Button Replacement: step 10, image 1 of 1
      • Lift the function set button ribbon cable from the two guide pins.
      Ask FixBot
    3. Canon PowerShot SD850 IS Function Set Button Replacement: step 11, image 1 of 1
      • Remove the ribbon cable by lifting on the flat tab and pulling the ribbon cable from the connection.
      Ask FixBot
iDeleted
2,101 Reputation
39 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 96
All Time: 1,710
