Canon PowerShot SD850 IS Flash Unit Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
88
All Time:
3,508
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 25 - 35 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
Use this guide to remove a broken flash unit from your Canon PowerShot SD850 IS.
Tools
    1. Canon PowerShot SD850 IS Flash Unit Replacement, Case: step 1, image 1 of 2 Canon PowerShot SD850 IS Flash Unit Replacement, Case: step 1, image 2 of 2
      • Remove the following 4 screws:
      • Two 2.8 mm Phillips #00 at the bottom of the camera.
      • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
      Ask FixBot
    2. Canon PowerShot SD850 IS Flash Unit Replacement: step 2, image 1 of 3 Canon PowerShot SD850 IS Flash Unit Replacement: step 2, image 2 of 3 Canon PowerShot SD850 IS Flash Unit Replacement: step 2, image 3 of 3
      • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
      • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
      Ask FixBot
    3. Canon PowerShot SD850 IS Flash Unit Replacement: step 3, image 1 of 2 Canon PowerShot SD850 IS Flash Unit Replacement: step 3, image 2 of 2
      • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
      • Slide light gray door and pull up to open the door.
      • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
      Ask FixBot
    4. Canon PowerShot SD850 IS Flash Unit Replacement: step 4, image 1 of 2 Canon PowerShot SD850 IS Flash Unit Replacement: step 4, image 2 of 2
      • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
      Ask FixBot
    5. Canon PowerShot SD850 IS Flash Unit Replacement: step 5, image 1 of 1
      • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
      Ask FixBot
    6. Canon PowerShot SD850 IS Flash Unit Replacement: step 6, image 1 of 1
      • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
      Ask FixBot
    1. Canon PowerShot SD850 IS Flash Unit Replacement, LCD Screen: step 7, image 1 of 1
      • Remove the 1.75 mm Phillips #00 located at the top left of the LCD screen.
      Ask FixBot
    2. Canon PowerShot SD850 IS Flash Unit Replacement: step 8, image 1 of 1
      • Remove the two 3.4 mm Phillips #00 located at the bottom of the camera.
      Ask FixBot
    3. Canon PowerShot SD850 IS Flash Unit Replacement: step 9, image 1 of 2 Canon PowerShot SD850 IS Flash Unit Replacement: step 9, image 2 of 2
      • Remove the two metal frames that hold the LCD panel in place.
      Ask FixBot
    4. Canon PowerShot SD850 IS Flash Unit Replacement: step 10, image 1 of 1
      • The LCD screen should now only be attached by two LCD data cables.
      • Lift the screen from the left side and use a spudger or a small flat head screwdriver to flip the black portion of the connector upward to unlock it.
      • Carefully slide the data cable out of the connector.
      Ask FixBot
    5. Canon PowerShot SD850 IS Flash Unit Replacement: step 11, image 1 of 1
      • The LCD should still be connected by the backlight cable.
      • To remove the backlight cable, use a spudger or a small flat head screwdriver to unlock the backlight cable.
      • Carefully slide out the backlight cable.
      • The LCD screen can now be fully detached from the camera body.
      Ask FixBot
    6. Canon PowerShot SD850 IS Flash Unit Replacement: step 12, image 1 of 2 Canon PowerShot SD850 IS Flash Unit Replacement: step 12, image 2 of 2
      • The LCD screen and housing are now in three pieces:
      • LCD screen
      • LCD screen frame
      • LCD back housing
      • The LCD screen itself can now be removed and fixed/replaced.
      Ask FixBot
    1. Canon PowerShot SD850 IS Flash Unit Replacement, Flash Unit: step 13, image 1 of 1
      • Remove the 1.85 mm #00 Phillips located on the left side of the camera.
      Ask FixBot
    2. Canon PowerShot SD850 IS Flash Unit Replacement: step 14, image 1 of 2 Canon PowerShot SD850 IS Flash Unit Replacement: step 14, image 2 of 2
      Tool used on this step:
      Buy
      • Use a set of tweezers to remove the speaker located at the top of the camera on the flash unit.
      • Next use the tweezers to carefully remove the speaker cable off its respective holders.
      Ask FixBot
    3. Canon PowerShot SD850 IS Flash Unit Replacement: step 15, image 1 of 1
      • Use a spudger or a flathead screwdriver to remove the camera lens cable located in the front of the camera.
      Ask FixBot
    4. Canon PowerShot SD850 IS Flash Unit Replacement: step 16, image 1 of 2 Canon PowerShot SD850 IS Flash Unit Replacement: step 16, image 2 of 2
      • Use a spudger or a flathead screwdriver and carefully pry out the first flash cable from the bottom of the cable. The white 2 prong power cable pops UP (use spudger below red/black insertion and put upward pressure). For the yellow one, apply pressure horizontally.
      • Next use a spudger or a flathead screwdriver and carefully pry out the second flash cable.
      Ask FixBot
    5. Canon PowerShot SD850 IS Flash Unit Replacement: step 17, image 1 of 1
      • Gently remove the flash component from the rest of the camera.
      • Use a spudger or a flathead screwdriver and carefully pry off the plastic piece on top of the flash unit.
      • The flash unit can now be removed and replaced.
      • Be careful not to touch the capacitor attached to the flash unit as it may still be holding a charge!
      Ask FixBot
Peter Tran
252 Reputation
6 Guides authored
Cal Poly, Team 20-7, Maness Fall 2010 Member of Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 88
All Time: 3,508
