Canon PowerShot SD850 IS Battery Replacement
  1. Canon PowerShot SD850 IS Battery Replacement, Battery: step 1, image 1 of 3 Canon PowerShot SD850 IS Battery Replacement, Battery: step 1, image 2 of 3 Canon PowerShot SD850 IS Battery Replacement, Battery: step 1, image 3 of 3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
    Ask FixBot
  2. Canon PowerShot SD850 IS Battery Replacement: step 2, image 1 of 2 Canon PowerShot SD850 IS Battery Replacement: step 2, image 2 of 2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
    Ask FixBot
To reassemble your device, follow thee instructions in reverse order.
Peter Tran
252 Reputation
6 Guides authored
Cal Poly, Team 20-7, Maness Fall 2010 Member of Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 52
All Time: 3,618
