Canon PowerShot SD780 IS LCD Screen Replacement
  1. Canon PowerShot SD780 IS LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • Turn the camera off by pressing the power button.
    • Also, make sure the battery is removed, as to avoid any shock injuries. To remove the battery located at the bottom corner of the camera, slide the panel towards the corner. Push the orange tab upwards and remove the battery.
    Ask FixBot
  2. Canon PowerShot SD780 IS LCD Screen Replacement: step 2, image 1 of 2 Canon PowerShot SD780 IS LCD Screen Replacement: step 2, image 2 of 2
    • Remove five screws from the camera casing using a Phillips #00 screwdriver.
    • There are two 2 mm screws located on the left side of the camera.
    Ask FixBot
  3. Canon PowerShot SD780 IS LCD Screen Replacement: step 3, image 1 of 1
    • Remove the front panel of the camera case to expose the top left copper strip.
    • Gently pull the copper strip upward and disconnect it from the camera.
    Ask FixBot
  4. Canon PowerShot SD780 IS LCD Screen Replacement: step 4, image 1 of 1
    • Remove the screw on the far left-hand side of the front of the camera using a Phillips #00 screwdriver.
    Ask FixBot
  5. Canon PowerShot SD780 IS LCD Screen Replacement: step 5, image 1 of 1
    • Carefully pull the case apart at the seam. The case will detach from the camera in two pieces.
    Ask FixBot
  6. Canon PowerShot SD780 IS LCD Screen Replacement: step 6, image 1 of 1
    • Remove the indicated "L" shaped bracket from around the bottom and right side of the LCD screen.
    Ask FixBot
  7. Canon PowerShot SD780 IS LCD Screen Replacement: step 7, image 1 of 1
    • Insert the flat side of your spudger tool carefully into the top of the LCD screen and lift the screen free.
    • Set the broken screen aside and place the new screen on top of the LCD screen.
    Ask FixBot
Arlene Ale
455 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 31
All Time: 1,662
