Canon PowerShot SD700 Outside Case Replacement
    1. Canon PowerShot SD700 Outside Case Replacement, Outside Case: step 1, image 1 of 1
      • Turn off the camera by pressing the power button above the LCD screen.
      Ask FixBot
    2. Canon PowerShot SD700 Outside Case Replacement: step 2, image 1 of 1
      • Remove the two small screws on the bottom of the camera using a Phillips #00 screwdriver.
      Ask FixBot
    3. Canon PowerShot SD700 Outside Case Replacement: step 3, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the two small screws on the right side of the camera.
      Ask FixBot
    4. Canon PowerShot SD700 Outside Case Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out digital label.
      Ask FixBot
    5. Canon PowerShot SD700 Outside Case Replacement: step 5, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the screw on the bottom of the camera near the battery and memory card slots.
      • This screw will be longer than the rest of the screws.
      Ask FixBot
    6. Canon PowerShot SD700 Outside Case Replacement: step 6, image 1 of 1
      • Remove the front, back, and side casings from the camera and set to the side.
      Ask FixBot
To reassemble your device, follow steps 1-6 instructions in reverse order.
3 other people completed this guide.
Emilio Rossi
113 Reputation
3 Guides authored
Cal Poly, Team 9-71, Walters Spring 2011 Member of Cal Poly, Team 9-71, Walters Spring 2011
CPSU-WALTERS-S11S9G71
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 23
All Time: 1,821
