Introduction
Go to step 1 ↓The shutter button is one of the most commonly used buttons on a camera. Therefore, it is also the most likely to break.
Tools
Slide open the battery cover.
Push the small orange tab to the side so the battery can be removed.
Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
Unscrew one .235 inch long Phillips screw using a #00 Phillips screwdriver from the top of the camera.
