Canon PowerShot SD500 Digital ELPH Image Sensor Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
84
All Time:
766
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The image sensor is what actually captures the image when you take a picture. If damaged, the sensor can cause blurred, distorted, or even black pictures.
Tools
    1. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, Battery: step 1, image 1 of 1
      • Slide open the battery cover.
      • Push the small orange tab to the side so the battery can be removed.
      Ask FixBot
    2. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 2, image 1 of 2 Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 2, image 2 of 2
      • Slide the battery out of the battery compartment.
      Ask FixBot
    1. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, Front and Rear Casing: step 3, image 1 of 2 Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, Front and Rear Casing: step 3, image 2 of 2
      • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
      • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
      • When looking at the back of the camera, these two screws are on the right panel of the camera.
      Ask FixBot
    2. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 4, image 1 of 1
      • Remove the right side cover from the camera casing.
      Ask FixBot
    3. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 5, image 1 of 1
      • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
      Ask FixBot
    4. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 6, image 1 of 1
      • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
      Ask FixBot
    5. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 7, image 1 of 1
      • Remove the left side cover from the camera.
      Ask FixBot
    6. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 8, image 1 of 1
      • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
      Ask FixBot
    7. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 9, image 1 of 2 Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 9, image 2 of 2
      • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
      • Remove the internal camera components and layout out all pieces on a clean surface.
      • The front and back cover may require gentle rocking to remove.
      Ask FixBot
    1. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, Button Contact Panel: step 10, image 1 of 1
      • Carefully wedge the pry tool under the ribbon in the ribbon gate.
      • Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
      • Be careful not to damage the ribbon.
      Ask FixBot
    2. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 11, image 1 of 1
      • Gently press the ribbon back to get access to a Phillips screw behind it.
      • Unscrew two .125 inch long Phillips screws using a #00 Philips screwdriver.
      Ask FixBot
    3. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 12, image 1 of 3 Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 12, image 2 of 3 Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 12, image 3 of 3
      • Remove the ribbon with a pry tool by gently pulling it out of the ribbon gate tab.
      • Pull the button board away from the rest of the camera.
      Ask FixBot
    1. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, LCD: step 13, image 1 of 1
      • Unscrew one .113 inch Phillips screw using a #00 Phillips screwdriver.
      Ask FixBot
    2. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 14, image 1 of 1
      • Lift the LCD screen up and away from the tab that holds it in place on the face of the camera.
      • Be careful, the LCD screen is still connect to the camera by a ribbon cable.
      Ask FixBot
    3. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 15, image 1 of 2 Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 15, image 2 of 2
      • Gently press the pry tool under the ribbon gate and lift up to free the ribbon connecting the LCD to the circuit board.
      • The LCD can now be completely removed from the camera.
      Ask FixBot
    1. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, Image Sensor: step 16, image 1 of 1
      • Place the pry tool under ribbon gate and gently lift it up, disconnecting the ribbon.
      Ask FixBot
    2. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 17, image 1 of 1
      • Unscrew three .15 inch Phillips screws from the back of the camera using a #00 Phillips screwdriver.
      Ask FixBot
    3. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 18, image 1 of 2 Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: step 18, image 2 of 2
      • Use the pry tool to gently lift the image sensor away from the rest of the camera.
      • Be careful not to damage the image sensor as you pry it up.
      Ask FixBot
Taylor Shields
861 Reputation
8 Guides authored
Clemson, Team 2-1, Benson Fall 2014 Member of Clemson, Team 2-1, Benson Fall 2014
CLEM-BENSON-F14S2G1
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 84
All Time: 766
