Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement
  1. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Battery: step 1, image 1 of 1
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
    Ask FixBot
  2. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 2, image 1 of 2 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 2, image 2 of 2
    • Slide the battery out of the battery compartment.
    Ask FixBot
  3. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Front and Rear Casing: step 3, image 1 of 2 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Front and Rear Casing: step 3, image 2 of 2
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
    Ask FixBot
  4. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 4, image 1 of 1
    • Remove the right side cover from the camera casing.
    Ask FixBot
  5. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 5, image 1 of 1
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
    Ask FixBot
  6. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 6, image 1 of 1
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
    Ask FixBot
  7. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 7, image 1 of 1
    • Remove the left side cover from the camera.
    Ask FixBot
  8. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 8, image 1 of 1
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
    Ask FixBot
  9. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 9, image 1 of 2 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 9, image 2 of 2
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
    Ask FixBot
  10. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Button Contact Panel: step 10, image 1 of 1
    • Carefully wedge the pry tool under the ribbon in the ribbon gate.
    • Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
    • Be careful not to damage the ribbon.
    Ask FixBot
  11. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 11, image 1 of 1
    • Gently press the ribbon back to get access to a Phillips screw behind it.
    • Unscrew two .125 inch long Phillips screws using a #00 Philips screwdriver.
    Ask FixBot
  12. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 12, image 1 of 3 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 12, image 2 of 3 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 12, image 3 of 3
    • Remove the ribbon with a pry tool by gently pulling it out of the ribbon gate tab.
    • Pull the button board away from the rest of the camera.
    Ask FixBot
  13. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, LCD: step 13, image 1 of 1
    • Unscrew one .113 inch Phillips screw using a #00 Phillips screwdriver.
    Ask FixBot
  14. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 14, image 1 of 1
    • Lift the LCD screen up and away from the tab that holds it in place on the face of the camera.
    • Be careful, the LCD screen is still connect to the camera by a ribbon cable.
    Ask FixBot
  15. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 15, image 1 of 2 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 15, image 2 of 2
    • Gently press the pry tool under the ribbon gate and lift up to free the ribbon connecting the LCD to the circuit board.
    • The LCD can now be completely removed from the camera.
    Ask FixBot
  16. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Flash Bulb Assembly: step 16, image 1 of 1
    • Arrange camera so it is facing up towards you.
    • Unscrew one .01 inch Phillips screw using a #00 Phillips screwdriver from the front of the camera.
    Ask FixBot
  17. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 17, image 1 of 1
    • Gently remove the indicated ribbon from respective ribbon gates.
    Ask FixBot
  18. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 18, image 1 of 1
    • Place spudger under white connector and gently lift it vertically out of its slot.
    • Be careful not to damage wire connector during removal.
    Ask FixBot
  19. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 19, image 1 of 1
    • Unscrew three .065 inch Phillips screws using a #00 Phillips screwdriver from the back of the camera.
    Ask FixBot
  20. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: step 20, image 1 of 1
    • Gently pull away flash bulb assembly from the rest of the camera.
    • Be careful not to damage the ribbon on the rest of the camera.
    Ask FixBot
Taylor Shields
861 Reputation
8 Guides authored
Clemson, Team 2-1, Benson Fall 2014 Member of Clemson, Team 2-1, Benson Fall 2014
CLEM-BENSON-F14S2G1
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 35
All Time: 618
